ITR clutch fit a 91 b18a??
Old May 30, 2005 | 12:26 PM
B18aHatch's Avatar
Default ITR clutch fit a 91 b18a??
hey i found a guy that is sellin a exedy clutch and fly wheel for a good price and he got it for a ITR. would this work for my b18a? are the splines the same??
Old May 30, 2005 | 12:54 PM
TSL's Avatar
TSL
i'm interested too, also i heard with some year LS tranny cases you can switch internals is this true?
Old May 30, 2005 | 09:31 PM
dcRay's Avatar
Default Re: ITR clutch fit a 91 b18a?? (B18aHatch)
If your B18a is using a cable tranny, then No.
Old May 30, 2005 | 09:43 PM
Kendall's Avatar
The flywheel and pressure plate will work, but the clutch disk will not.
Old May 31, 2005 | 01:16 AM
jaydeemmmm's Avatar
Default Re: ITR clutch fit a 91 b18a?? (dcRay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcRay &raquo;</TD></TR><TR><TD CLASS="quote">If your B18a is using a cable tranny, then No.</TD></TR></TABLE>
^ The clutch won't work on the cable tranny. All the 94+ Integras are using the Hydro tranny. Unless you want a Cable to Hydro swap, which I DO NOT recommend. Pain in the *** kind of job.
92TypeR: I can finish 4 motor swaps before I even finish a Cable to Hydro swap.
Old May 31, 2005 | 07:48 AM
projectTeG's Avatar
Default Re: ITR clutch fit a 91 b18a?? (jaydeemmmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeemmmm &raquo;</TD></TR><TR><TD CLASS="quote">
92TypeR: I can finish 4 motor swaps before I even finish a Cable to Hydro swap.</TD></TR></TABLE>
ok....ppl need to start get their facts straight and stop speading mis -information....what kendall said was right..... cable and the hydrolic system of the tranny has nothing to do if the clutch will work or not, the 90-91 usdm and i believe the 89-90 jdm b-series trannies have a smaller clutch spline than the 92-up trannys....so if you have a1, s1, or j1 tranny it wont work only the pp and flywheel will work
efcivic12
Nov 8, 2008 07:40 AM
luvs2spooge
Aug 31, 2007 06:34 AM
SiBuddy00
Jun 21, 2005 07:57 PM
lilxvtecxpwr
Feb 11, 2005 11:47 AM
mildly.interesting
Feb 7, 2005 09:09 PM
