car sways in water..
Old May 30, 2005 | 11:33 AM
rodvang's Avatar
Default car sways in water..
The past few days have been raining and when I drive my car it feels like the car kind of sways from side to side a little. I know that I need to change my inner and outter tie rods but would this be causing the swaying? the front tires also have low thread so this could also be the problem...it sort of feels like the back is the part that is swaying and then I correct it with the steering...what are your thoughts on this problem?
Old May 30, 2005 | 11:39 AM
postman's Avatar
Default Re: car sways in water.. (rodvang)
its called hydroplaning
Old May 30, 2005 | 11:40 AM
Jorsher's Avatar
new tires?
Old May 30, 2005 | 11:58 AM
prwil3030's Avatar
Default Re: car sways in water.. (postman)
So, how do you fix the (hydorplaning)?? Im having the same problem with my 00 Si, it can be wet or dry. I feel it when I'm speeding. I have new tires, new suspension, new tie rod, ect. This start happening after I took the sway bar off to isntall the new suspension. I think, it has to be someting with the sway bar. I'm getting ready to buy a sway bar for 98 Itr wich is 23 mm, this might fix the problem. Let's see.
Old May 30, 2005 | 12:01 PM
jeff on pluto's Avatar
Default Re: car sways in water.. (prwil3030)
you cant stop hydroplaining.... thats what happens in water
Old May 30, 2005 | 12:03 PM
syked's Avatar
mine stopped doing that when i got it aligned after changing my suspension
Old May 30, 2005 | 12:10 PM
Street Ghost's Avatar
Default Re: (syked)
get better tires
bobinyelm
Honda CR-V & Element
Sep 11, 2017 06:37 PM
solo2civic
Suspension & Brakes
Feb 8, 2005 09:14 PM
ee-gsr
Apr 14, 2004 07:13 AM
robinson
May 13, 2002 05:10 PM
RineRacing
Aug 6, 2001 12:14 PM
