Will this motor be a straight bolt in?
Old May 30, 2005 | 06:40 AM
civic-si-2000's Avatar
Default Will this motor be a straight bolt in?
Plus can I use the new shift linkage on my car?
http://hmotorsonline.com/shop/...30005
Old May 30, 2005 | 06:44 AM
egryda's Avatar
Default Re: Will this motor be a straight bolt in? (civic-si-2000)
what year is your car? 2000?
Old May 30, 2005 | 07:05 AM
Default Re: Will this motor be a straight bolt in? (egryda)
Yeah. I pulled my motor yesterday and had to cut the linkage that bitch pin.......
Old May 30, 2005 | 05:13 PM
egryda's Avatar
im pretty sure all b series linkages are the same.
Old May 30, 2005 | 05:14 PM
1995Ex_Sedan's Avatar
[Hijack] Congrats egryda! [/Hijack]
Old Jun 1, 2005 | 05:04 PM
typeoneeg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egryda &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure all b series linkages are the same.</TD></TR></TABLE>
del sol is different. you can get on hasports website and it will tell you everything you need.
Old Jun 1, 2005 | 05:08 PM
typeoneeg6's Avatar
Default Re: Will this motor be a straight bolt in? (typeoneeg6)
yes it should bolt right in. same motor that came out of your car. hydro tranny just like yours. but you cut the linkage?
Old Jun 1, 2005 | 05:11 PM
EG-B18CR's Avatar
for Hmotors
Old Jun 1, 2005 | 09:48 PM
egryda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeoneeg6 &raquo;</TD></TR><TR><TD CLASS="quote">yes it should bolt right in. same motor that came out of your car. hydro tranny just like yours. but you cut the linkage?</TD></TR></TABLE> yeah im trying to figure that out too. you can just grind the head off the pin and use a punch and knock it out.
C_I_V_I_C
May 25, 2006 07:51 AM
EJ8 GSR-T
11
Apr 15, 2006 01:33 PM
BigDawwg6969
Aug 16, 2005 09:59 AM
luti
Oct 9, 2004 11:35 AM
DMF
Sep 16, 2003 08:18 PM
