B16A ECU question
I have a new Teg with a B16A, 1st gen and the swap is in complete with tranny! The entire drivetrain is I guess SIR. The ECU is spitting a 6 and a 23 code, does anyone have clue as to what it is?
If its a Pr3 Which i would assume if your running OBD0 First GEn b16, code 23 is for the knock sensor, you must put a knock sensor on your motor and wire it to Pin B19 on the ECU i believe. Know Code 6 i must tell you to SEARCH. I gave you 23 and didn't yell at you to search but to further your knowledge click search.
I did do a search, but I didn't find it; however I tried it again, typed it differently and low and behold I found what I was looking for!! Thanks for the reply just the same!!
dont know why the ecu codes thread isnt locked any more...but i went to the civic forum and got that link
https://honda-tech.com/zerothread?id=1171263
madman4you
May 3, 2006 08:34 AM
