ABS fault code 1 3 (high pressure leakage)
Old May 30, 2005 | 06:01 AM
Sandfeld's Avatar
Default ABS fault code 1 3 (high pressure leakage)
My 1994 european Civic with a B16A2 engine shows a fault code 1 3 (high pressure leakage). It doesn't seem to be using any measureable brake fluid. The the abs indicator light only turns on sometimes. When you start the car, you can hear the modulator making this buzzing sound a couple of seconds at a time and it continues to do so until the ABS indicator turns on, also during driving. It's like it's trying to build up pressure every once in a while. The Honda dealership where I live doesn't have the the special tool to test the ABS system. They just say that I need a new modulator at a list price of almost $3000 here in Denmark. I find this very expensive and I am hoping that the problem isn't so bad that the modulator needs to be replaced. I really really hope you can help me....
Best Regards
Dennis Sandfeld
srd....
Nov 12, 2019 06:58 PM
Fitz Williams
Jun 16, 2019 04:47 AM
thtguybryan
Mar 18, 2017 06:47 AM
jaysome01
Apr 30, 2006 08:35 PM
