Compustar 2WSS-AS users I have a question.
I currently have the compustar 2WSS-AS which is the pager alarm with autostart. I've noticed that sometimes even when I do the correct reservation mode and I hear the chiming music that in the mornings I can't auto start. It happens fairly often enough to **** me off. I took it back to where I got it from and they changed the "brain" of the alarm for me. It was a little better but for some reason I still get some mornings that it refuses to autostart. The range on the alarm though is great. Anyone else have this problems or can someone offer an explanation?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iixerOii »</TD></TR><TR><TD CLASS="quote">I currently have the compustar 2WSS-AS which is the pager alarm with autostart. I've noticed that sometimes even when I do the correct reservation mode and I hear the chiming music that in the mornings I can't auto start. It happens fairly often enough to **** me off. I took it back to where I got it from and they changed the "brain" of the alarm for me. It was a little better but for some reason I still get some mornings that it refuses to autostart. The range on the alarm though is great. Anyone else have this problems or can someone offer an explanation?</TD></TR></TABLE>If the "brain" has already been replaced, then I would look at the install, I have installed a lot of Compustar alarm/remote starts, and have not run into that problem very often, and when I have, the problem was in the "brain", [once or twice] I have also seen the problem on customer installed units, they always turn out to be poor install techniques, [ unsoldered connections]
94
94
Where can you buy this compustar alarm system? Are these better than all the other alarm system such as viper, clifford, and all the other brands. Need opinions and does it have a fuel cutoff? Sorry kind got off track with the post...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JPamonag »</TD></TR><TR><TD CLASS="quote">Where can you buy this compustar alarm system? Are these better than all the other alarm system such as viper, clifford, and all the other brands. Need opinions and does it have a fuel cutoff? Sorry kind got off track with the post...</TD></TR></TABLE> They are very good alarm/alarm remote starts, unlike DEI, they make an alarm remote start for standards, yes it has outputs that can be used for fuel cut off and you can find the closest dealer here http://www.compustar.com
94
94
