b18 b16 valves interchangable?
Old May 29, 2005 | 08:53 PM
Littlegreend15's Avatar
Default b18 b16 valves interchangable?
heres what happpened, over revved, problems, turned out to be bent valves, the post is here https://honda-tech.com/zerothread?id=1260163 . anyway, i'm pulling the head and taking it to a machine shop to check/fix valve seats, and obviously i need some new valves, so my question is, are jdm b18c valves interchangable with b16 valves, because theres a honda dealer close where i can order some new b16 valves, but no acura dealer close, or possabley somewhere else i can buy valves, i don't want to spend the money on performance valves, i just want to replace the bent ones, and i don't know where to get them other than a dealer
Old May 29, 2005 | 09:17 PM
unknown0001's Avatar
Default Re: b18 b16 valves interchangable? (Littlegreend15)
I'm not sure if the valves are the same.
The only thing making me belive they aren't is that the b16 head may be setup differently to work on the 1.6L motor. It might be that the valves will be a bit smaller then the GSR b18c1 valves.
Search here on honda-tech and you can probobly pickup a set of valves for cheap for the b16
Old May 30, 2005 | 04:55 AM
Default Re: b18 b16 valves interchangable? (Mr.RHTuner)
bump
Old May 30, 2005 | 09:21 AM
come on guys, i need to know, help me out, i'm gonna cry
Old May 30, 2005 | 11:11 AM
ITRSol's Avatar
hey man if you find out let me know. I'm in the same boat as you. my b18c warped the valves too
Old May 30, 2005 | 11:40 AM
_BEN_'s Avatar
Compare the part numbers @
http://www.acuraparts247.com
http://www.hondapartssource.com
If they are the same you are good to go.
jceltalentoso
14
Jan 20, 2012 03:45 AM
jceltalentoso
Jan 18, 2012 10:23 AM
egsr6
Jul 18, 2006 07:54 AM
bluegdx16
Feb 17, 2005 06:59 PM
