Omnipower Coilover Adjustment Help???
Old May 29, 2005 | 08:47 PM
jdmvtec28's Avatar
Default Omnipower Coilover Adjustment Help???
To those ITR owners that run omni full body coilovers...
I have recently installed a set per the instructions (setting preload etc.) and to my dismay the front end sits at stock or above and is lower on one side than the other. Mind you this is achieved when the threaded colar is all the way down. I have no problems with adjustability in the rear, just in the front. I will attempt to contact omniman on Tuesday after the holiday, but was hoping someone could provide some feedback prior to the work week begining so I could have a functional car. The only solution I have to this is to ignore the preload instructions and lower the car via the spring perch. Comments Advice??
Old May 29, 2005 | 09:13 PM
B2FiNiTY's Avatar
Default Re: Omnipower Coilover Adjustment Help??? (jdmvtec28)
Is your set Integra specific on the box?
Also, did you raise the sleeve all the way up?
Old May 29, 2005 | 09:54 PM
{Powered by VIII}'s Avatar
Default Re: Omnipower Coilover Adjustment Help??? (B2FiNiTY)
is it sitting all the way down in the fork?
Old May 29, 2005 | 10:49 PM
jdmvtec28's Avatar
Default Re: Omnipower Coilover Adjustment Help??? ({Powered by R})
Yes my application was specifically for the DC2 ITR. The threaded part of the coilover is threaded all the way into the lower piece of the coilover.
And yes, the forks are all the way up against the lip of the coilover...
Any other suggestions?
Old May 30, 2005 | 04:03 AM
btotherizzle's Avatar
Did you compare your stock coil to the omni one? If so what was the height difference? Sounds to me like you didn't measure things.
Old May 30, 2005 | 08:15 AM
jdmvtec28's Avatar
Default Re: (btotherizzle)
Your right I didn't... But when I compare the omni coil to the Nuespeed and Tokiko Setup I had on the car, the omnis come up about an inch longer in the front... Besides what does the stock shock and coil length have to do with the fact that the omnis will not go any lower without ignoring the preload instructions to drop the car?
Old May 30, 2005 | 09:22 AM
jdmspoonitr's Avatar
Default Re: (jdmvtec28)
I don't know what you did wrong, but my omni's can lower the car considerably in the front
Old May 30, 2005 | 09:28 AM
Chris F's Avatar
Default Re: (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">I don't know what you did wrong, but my omni's can lower the car considerably in the front</TD></TR></TABLE>
Yeah, seriously, I am slammed and have an inch or two farther I could go.. Omni sport 12k/10k. Some people complain they can't get it back up to stock height.
Chris F's Avatar
Default Re: (Chris F)
Take pictures of the height and the installation. *shrug*
Old May 30, 2005 | 02:29 PM
jdmvtec28's Avatar
Tomorrow I will call into omni and see what he advises, I will also snap some pics and post them as well.
Old May 30, 2005 | 03:52 PM
let us know and pics would be cool.
Old May 31, 2005 | 07:17 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, seriously, I am slammed and have an inch or two farther I could go.. Omni sport 12k/10k. Some people complain they can't get it back up to stock height.</TD></TR></TABLE>
exactly my situation.. and my car looked like a 4x4 with the stock suspension, so I have no idea what the issue here is without pics..
Old May 31, 2005 | 06:06 PM
jdmvtec28's Avatar
Default Re: (mstewar)
I spoke with Dave & Bob at omni today... apparently there are 2 different length threaded bodies manufactured. They think I was shipped the longer of the two which is about 2 inches longer than the shorter one. I'll keep everyone posted.
KennethIsHOT
Suspension & Brakes
33
Jul 13, 2012 11:52 PM
wite2nr
Suspension & Brakes
Jan 6, 2010 09:11 AM
FlipSide24
Suspension & Brakes
Mar 3, 2009 06:26 PM
suno
Suspension & Brakes
Apr 16, 2008 06:08 PM
needashell1234now
Suspension & Brakes
Jan 27, 2007 11:35 AM
