rpm needle jumping
Old May 29, 2005 | 08:06 PM
eg4door's Avatar
Default rpm needle jumping
OK I put a cam and gear in last week and now for some reason when I go over 6000rpm the needle will start jumping. Then I had moved the timing a bit and it stoped. I moved the timing today and it started. Does this make sense. Can it be if the timing is a little out, the needle will jump or can the cluster be no good?
Old May 29, 2005 | 09:34 PM
blackeg's Avatar
Default Re: rpm needle jumping (eg4door)
usually a sign of the ignition coil going bad i believe...
Old May 30, 2005 | 02:45 AM
eg4door's Avatar
Anyone else had this happen. If it is the coil I'll look into one now.
Old May 30, 2005 | 01:15 PM
eg4door's Avatar
Old May 30, 2005 | 08:11 PM
b18c1wes's Avatar
i know this sounds stupid but check to make sure you tightened the 10mm bolt on the distributor that you loosened to change the timing.. would cause this to happen.... besides that i dunno
XVNVX
Aug 7, 2017 10:31 AM
stryker gs
Mar 25, 2013 02:30 PM
4drint3gr4
17
Oct 14, 2010 09:54 PM
johnwohl
Apr 1, 2008 07:29 PM
whiteboy03si
Mar 14, 2007 03:27 PM
