Cluster options of 96 CX Hatchback?
I had an 97 EX cluster that I bought from eBay. Problem is that my son played with the needle on the fuel and temperature needle and broke the needle and looks like the motors also. I tried to fix the needle on both gauges. However, after installing on the car, both gauges did not work.
So... Am I really stuck with just an EX cluster if I wanted a tachometer? Are there other clusters which would be just plug and play on a 96 CX Hatchback?
Thanks!
Thanks!
If you want a tachometer there is the Si cluster, 97-01 CRV cluster, CTR cluster, Spoon cluster, Mugen cluster, SIR cluster, canadian 1.6 EL cluster, and a few others I can't remember. All plug and play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">u can take the guages apart i think and swap in the ones that work.</TD></TR></TABLE>
Tried it w/ my CX cluster and the screw holes didn't line up. It may work w/ others but it wont for the CX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Just buy a new temp/fuel gauge from Honda. Probably won't cost more than $30.</TD></TR></TABLE>
I think this is the route I will pursue.
Thanks!
Thanks!
Checked with a Honda dealership as to how much a fuel and temp gauge is. Cost is $54 + tax.
Any other place I should check?
Check http://www.hondaautomotiveparts.com as well as http://www.slhonda.com
