Skunk2 IM concern
guys,
I am in a process to buy a IM Skunk2 for my JDM SIR-G B18C.
<U>My concern/questions are</U>:
1.what TB will be fine for this IM?
2.Now that I cannot use my CAI AEM that is on my Stock IM, what CAI AEM model should I buy?
3.also>what size TB does GSR or SIRG comes with? and again what size will be recommendable for the skunk2 IM?
4.Will this all be BOLT on, with all the sensors and all?
thanks in advance for help,
Rishi
Rishi
ha, i just asked this question and got almost NO help at all.. good luck. https://honda-tech.com/zerothread?id=1256193
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rishiras »</TD></TR><TR><TD CLASS="quote">guys,
Rishi</TD></TR></TABLE>
1. you can use your stock TB or you can get one of those aftermarket ones.
2. you can use your gsr cold air. but you might have to cut it in half and put a cuppler there or an ITR or LS will work.
3. i don't know what size it is but it's a tiny bit smaller then the skunk2 mainfold inlet.
4. yes everything bolts up just fine
ur stock im, or an itr will be good depending on mods.
aem comp.
60 or 62mm
yes
aem comp.
60 or 62mm
yes
djphoebus
Dec 24, 2004 04:12 PM
