98 Honda accord-Will not start, Help!!
Old May 29, 2005 | 03:42 PM
vmbankers@aol.com's Avatar
Default 98 Honda accord-Will not start, Help!!
I have 1998 Honda Accord just "click" when turning ignition key. Replaced battery, cleaned terminals-still "click". Lights, locks, windows, radio all work, please help
Old May 29, 2005 | 03:52 PM
C_H_A_D's Avatar
Default Re: 98 Honda accord-Will not start, Help!! (vmbankers@aol.com)
Well... Maybe there is a killer after you!
Old May 29, 2005 | 04:58 PM
deserthonda's Avatar
sounds like you might have starter issues...get a big screwdriver.
have a friend try to start car when it click hit starter with it if it turns over there is your problem if not make sure you are getting power to the starter main + solenoid wires
Old May 29, 2005 | 05:39 PM
Default Re: (deserthonda)
Thanks for tip! Question-how to determine if starter/soleniod getting power?Another posting mentioned a relay any thoughts on that.
Old May 29, 2005 | 05:59 PM
SPEED FoRCE's Avatar
if its clicking, the relay should be fine, are you 5spd or auto?
Old May 29, 2005 | 09:40 PM
if you have a manual tranny try pushstarting it ,,,have you tried to hit starter?? anything happen???
Old May 29, 2005 | 10:04 PM
Davidxx's Avatar
It may be your starter, alternator, or lastly "timing belt" is broken. Check them 3 stuff. I have a similar issue with my 87 LXi (Fuel Injection), but mine was able to crank it up, however, it won't start up. So, in the end, I found out that it was my ECU all along. I replaced my ECU and now back in bussiness.
Old May 30, 2005 | 04:13 AM
It has an automatic tranny so pushing is not an option hopefully neither is towing. The ECU is that an option? Can that cause a no start? I have tried whacking the starter no luck.
Old May 30, 2005 | 04:43 AM
teler86's Avatar
Default Re: (vmbankers@aol.com)
your alternator might be broken, try checking to see if it's siezed or not puting out enough amprege
Old May 30, 2005 | 07:15 AM
Default Re: 98 Honda accord-Will not start, Help!! (VTECJedi)
Apparently we know each other-otherwise what is up w/the comment
Old May 30, 2005 | 07:18 AM
C_H_A_D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vmbankers@aol.com &raquo;</TD></TR><TR><TD CLASS="quote">Apparently we know each other-otherwise what is up w/the comment </TD></TR></TABLE>
I was only Joshin dude
Old May 30, 2005 | 09:06 PM
fubuallstar's Avatar
take off the starter take it to autozone and test for free . im not to sure but about this but try putting the car in neutral and start it {without pushing it}
Derrick Carr
Honda CR-V & Element
Jan 24, 2018 06:30 AM
needhondahelp90
Nov 25, 2014 11:46 AM
norbertocartage
Feb 25, 2013 07:30 AM
66elwood99
Sep 7, 2007 01:09 PM
ZexyAccord
Jan 9, 2006 03:34 PM
