Will a Civic SI Stock exh manifold fit on an Integra LS motor?
Old Feb 7, 2002 | 02:38 PM
Ri5e's Avatar
Default Will a Civic SI Stock exh manifold fit on an Integra LS motor?
I know it will fit, but will the collector/flange fit to the cat convertor/test pipe?
I'm going "all motor" for now...till I get a new turbo.
Thanks.
Old Feb 7, 2002 | 02:44 PM
cyan1de's Avatar
Default Re: Will a Civic SI Stock exh manifold fit on an Integra LS motor? (BG Boost)
it should, all b series exhaust manifolds should bolt up to all b series heads.
Old Feb 7, 2002 | 04:25 PM
InfamousRS's Avatar
Default Re: Will a Civic SI Stock exh manifold fit on an Integra LS motor? (cyan1de)
The stock manifold on the SI is shorter probably because the hight of of the b16 vs. the taller b18. It might have a problem of clearing the oil pan. I may be wrong though.
Old Feb 7, 2002 | 05:25 PM
dustin's Avatar
I think it will bolt straight up.
Old Feb 7, 2002 | 06:34 PM
turboex's Avatar
Default Re: Will a Civic SI Stock exh manifold fit on an Integra LS motor? (dustin)
if you use the whole thing it will but if you try mix the upper and lower parts then the wont. see the b16 and ls bolts line up diffrent. i mean the joint between the upper header and lower part
Rok_Stok
Nov 3, 2011 08:13 PM
G-Auto*Hero
Aug 1, 2009 07:37 PM
v8 integra
Jan 13, 2008 11:45 AM
oneforce
May 31, 2005 06:29 PM
HX_Guy
Aug 6, 2002 08:38 AM
