Will a Civic SI Stock exh manifold fit on an Integra LS motor?
I know it will fit, but will the collector/flange fit to the cat convertor/test pipe?
I'm going "all motor" for now...till I get a new turbo.
Thanks.
Thanks.
Re: Will a Civic SI Stock exh manifold fit on an Integra LS motor? (BG Boost)
it should, all b series exhaust manifolds should bolt up to all b series heads.
Re: Will a Civic SI Stock exh manifold fit on an Integra LS motor? (cyan1de)
The stock manifold on the SI is shorter probably because the hight of of the b16 vs. the taller b18. It might have a problem of clearing the oil pan. I may be wrong though.
Re: Will a Civic SI Stock exh manifold fit on an Integra LS motor? (dustin)
if you use the whole thing it will but if you try mix the upper and lower parts then the wont. see the b16 and ls bolts line up diffrent. i mean the joint between the upper header and lower part
