:did i mess this up!?!: brake caliper question.
Old May 29, 2005 | 01:37 PM
spock_rocker's Avatar
memoryFAB.com representative
Default :did i mess this up!?!: brake caliper question.
on the back side of the caliper where the brake line bolts to, i removed the line in preperation for new SS lines, well i put the bolt back in to prevent from spilling fluid everywhere. well my dumbass ended up tighing it all the way down!! now i can get it out! the bolt will rotate both ways with a wrench and im kinda hoping a didn't strip it and if i did.. is there any way i can save the threads on the caliper side? thank you for you help.. oh and its circles in red!
Old May 29, 2005 | 01:41 PM
Kyles ej1's Avatar
Default Re: :did i mess this up!?!: brake caliper question. (spock_rocker)
yea its stripped
Old May 29, 2005 | 01:47 PM
Default Re: :did i mess this up!?!: brake caliper question. (93ejay1)
can i get it out without messing up the threads on the caliper side?
Old May 29, 2005 | 01:49 PM
pdiggitydogg's Avatar
IF you can get it out you can retap and it might be alright.
How youd get it out is a good question. I cant remember if it sticks out into the area behind the piston or not...pull it out and check
Old May 29, 2005 | 02:16 PM
Default Re: (pdiggitydogg)
the problem is i cant get the bolt out at all.. its like its stuck in there. ive tryed pulling on the bolt with vise grips and i cant get it free. if i could get it out then i could pre detemine the stripped situation.
Old May 29, 2005 | 02:17 PM
95hatchd16y8's Avatar
sorry to say but its stripped
Old May 29, 2005 | 02:41 PM
Like I said
Remove the piston and see if the bolt is within that chamber.
You may be able to press on the bottom of the bolt while turning it (thats if there is any sort of thread)
Old May 29, 2005 | 02:44 PM
Good ol' Screwtape's Avatar
Multi-paradigm
if all else fails...new assembly at junk yard = $20.
Old May 29, 2005 | 02:56 PM
nocturnaldragon's Avatar
the threads on the caliper are probably still good, being that the steal in the bolt is softer then the caliper. You probably striped all the threads and crushed the ones on the inside over preventing you from pulling it out.
Your best bet is probably to drill the SOB out then re tap if necessary. Remember to use a smaller bit then the threads and start out small and work your way up slowly that way if you don't start out dead center you have some mercy room before you damage the threads with the drill bit.
Once you have it drilled out and have a shell of a bolt left take a chisel and clean out the rest of the bolt. Clean out the shavings and see what you have.
Or just get a new one......
Old May 29, 2005 | 03:05 PM
UH8MYVTEC's Avatar
My guess: You tightened the bolt all the way past the threads. This is the part that is in the brake line banjo fitting. I suppose that you are not able to back the bolt out by pulling and turning.
Forget a junk yard, jus tturn that thing in as a core at Autozone for a freshly rebuilt one.
Old May 29, 2005 | 03:09 PM
blac00si's Avatar
Default Re: (UH8MYVTEC)
time for new calipers to go with those SS lines
Old May 29, 2005 | 03:27 PM
_BEN_'s Avatar
Default Re: (Blac00si)
Did you attempt to pry it out while loosening it?
This will require some help.
Take a screwdriver and wedge it under the lip of the bolt and try to pry it out. At the same time try losening it with a wrench.
If there is any threads left hopefully they will catch and it will start to back out.
Old May 29, 2005 | 04:22 PM
canis's Avatar
dude i did the same thing, and i F*ucked the thing up the same way but i did it with the line on and did the same thing, calipers are cheep, there not to bad so dont worrie to much..
Old May 29, 2005 | 04:55 PM
I still say that you can press the bolt from the other side and turn it out.
If you decide you want to say "**** it" I have a set of ex/si calipers that I'll sell for a good price
Old May 29, 2005 | 05:09 PM
its a gsr caliper and i only need the right side. yes i did try to pry when loosening. i think im just gonna try and get another one.
Old May 29, 2005 | 09:32 PM
canis's Avatar
Default Re: (spock_rocker)
now remeber if your getting a new one, get the same one, or if your going to up grade you have to get both... but either way its not hard..
Old May 30, 2005 | 07:20 AM
Did you try removing the piston and pressing the bolt from the bottom??
(Its an integra caliper...gsr isnt special)
Old May 30, 2005 | 07:21 AM
i wasn't sure how to remove the piston, im just gonna look into getting a new integra caliper. thanxx
Old May 30, 2005 | 07:26 AM
What if its fixable? Youre willing to just dump more cash?
Remove the bleeder screw and you should be able to pry the piston out a little. After that grab it with some vicegrips or something (with a rag so you dont damage it) and pull it straight out.
Old May 30, 2005 | 07:34 AM
eg crunkmonster's Avatar
a brand new caliper at autozone is $30 with core......i suggest u do that
Old May 30, 2005 | 08:28 AM
elise's Avatar
that or helicoil
Old May 30, 2005 | 08:40 AM
Default Re: (eg cookiemonster)
i checked there webpage, there 46.00, i was quoted 50.00 from the junk yard that i got the conversion from.
gunrok
Feb 29, 2016 02:00 AM
skacoreimplore
Dec 8, 2010 02:39 PM
tommyofyork
Apr 6, 2007 01:53 PM
Filliam H. Muffman
Sep 13, 2006 09:38 AM
joe pagolac
Jul 16, 2005 09:28 PM
