removing stickers\decals from body
Old May 29, 2005 | 01:04 PM
DC4_MADMAN's Avatar
Default removing stickers\decals from body
The previous owner had alot of decals\stickers on the car, now I need to remove them. Whats the best way of doing this without jacking up the paint?
I know amonnia is used to remove them from windows, but will amonnia **** up the paint or should I use it?
Thanks.
Old May 29, 2005 | 01:07 PM
dc2vu's Avatar
Default Re: removing stickers\decals from body (4door_demon)
i just peeled it off...there will still be some glue or adhesive on there...use gasoline to get that **** off
Old May 29, 2005 | 01:08 PM
RJwaggs's Avatar
Well, when doing slave work and scrubbing the shelves clean of nasty goo left behind by the item UPC stickers, Goo Gone worked REALLY well, and didnt mess up any surfaces.
Old May 29, 2005 | 01:13 PM
Kyles ej1's Avatar
Default Re: (RJwaggs)
try a heat gun, it should come off pretty easily.
do u have to let goo gone sit or something cuz ive tried it before and it didnt work for me.
Old May 29, 2005 | 01:19 PM
RJwaggs's Avatar
Default Re: (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">try a heat gun, it should come off pretty easily.
It helps if you let it sit for 3-5mins, but for me it worked almost instantly. Could be different EURO SPEC Goo Gone though
Old May 29, 2005 | 01:30 PM
Solid Alibye's Avatar
Yeah I've had good luck using a heat gun and if there's any residue left over then Goo Gone works well!
Old Jun 4, 2005 | 09:16 PM
stickershop.ca's Avatar
Since there is the risk of removing paint with the decal, you must be very careful. You will need to use a hot hair dryer or a heat gun to soften up the adhesive while you *slowly* peel the decal off. Then use an adhesive remover product to remove the sticky residue.
Keep in mind that the paint under the decal has been protected from the elements and may appear less faded than the paint around the decal. Depending on how long the decals were on the car, and the colour of your paint, you may still be able to see a silhouette of where the decal used to be.
Old Jun 4, 2005 | 09:24 PM
zeroek's Avatar
Default Re: removing stickers\decals from body (stickershop.ca)
Use a heat gun or Hair dryer. I like to buy some Car Brite All Sol. Takes the sticky stuff off.
Old Jun 5, 2005 | 11:54 AM
ant123's Avatar
peel it off slowly...and go get some goo b gone....at like a rite aid or a conveincie store
Old Jun 5, 2005 | 11:59 AM
MAKK Performance's Avatar
Building cars/Breaking records
Default Re: (ant123)
depending on the amount of sticker , go to a paint and body shop and get "pin stipe removing tool,, its like a giant eraser on a wheel , they work great
Old Jun 5, 2005 | 12:27 PM
B16aDasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RJwaggs &raquo;</TD></TR><TR><TD CLASS="quote">Well, when doing slave work and scrubbing the shelves clean of nasty goo left behind by the item UPC stickers, Goo Gone worked REALLY well, and didnt mess up any surfaces.</TD></TR></TABLE>
yeah, i love goo gone. Its the sh*t.
Old Jun 5, 2005 | 01:16 PM
t0ekn3e's Avatar
heat gun
Old Jun 5, 2005 | 02:47 PM
DBLAZE's Avatar
Default Re: (t0ekn3e)
I gotta do the same thing with some small stickers on the back of mine too...cool...
[Eg.6]LiLbOy916
Oct 28, 2006 09:23 AM
Honda_18
25
Dec 5, 2004 02:38 PM
redteg1
Feb 23, 2004 12:00 PM
EM1Guru
Sep 29, 2003 12:39 PM
preludacris
Mar 10, 2003 04:11 PM
