Rust question
Old May 29, 2005 | 12:32 PM
cbmprelude's Avatar
* B A N N E D *
Default Rust question
I looking into an eg hatch but it has a bit o' cancer on it. How much will it run to get replacement quarter panel installed an painted on both sides?
Old May 29, 2005 | 01:00 PM
nocturnaldragon's Avatar
Default Re: Rust question (cbmprelude)
Wont be cheap, Ill gaurantee that, they have to be cut out and rewelded into place, bondo'd and painted x2. Im getting my car ready for paint and Its taking me twice as long to get the rust out on the quarters as it did for everything else.
Old May 29, 2005 | 01:31 PM
ch4nq's Avatar
yeah true, wont be cheap. unless you do it yourself like me. =D
1.buy a new panel
2.cut out rusted areas
3.grind to metal and clean rust **** off
4.weld new panel on, make sure its in the right place
5. bondo, sand, seal, prime and prime and prime.
6. wet sand
7 prime seal, and paint your color.
Old May 29, 2005 | 01:37 PM
hatch34's Avatar
Default Re: Rust question (nocturnaldragon)
yea fixing honda rust if its bad is not cheap by any means
Old May 29, 2005 | 11:08 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: Rust question (hatch34)
Darnet, are there any other major rust spots to look out for when buying an eg hatch?
Old Jun 1, 2005 | 10:11 AM
exploder101's Avatar
https://honda-tech.com/zerothread?id=1237275 I bought a rear quarter panel of this place for $36.00 shipped. Better than paying OEM prices.
Old Jun 1, 2005 | 11:17 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: Rust question (exploder101)
Thanks for the link exploder101
I got pics of the rust on the hatch today, please ignore the fruity pin stripping.
Driver side rear quarter panel
Here is the rear driver fender lining
Here is the front of the wheel well
Driver door
Passenger side rear of wheel well
here is the front base of that wheel well
If we continue down that panel we see
Old Jun 1, 2005 | 11:27 AM
cbmprelude's Avatar
* B A N N E D *
The hatch seems to be in good shape mechanically and the owner is a great guy I have known a long time. Im just worried how much this rust will cost me? What do you guys think?
Old Jun 1, 2005 | 11:29 AM
Jamez's Avatar
Pretty much all EGs from the northen part of the States and Canada are gonna be like that. You either have to live with it or pay the price to repair it (and if you find one that's rust free your again gonna pay the price, no way around it).
Old Jun 1, 2005 | 12:16 PM
alleyezonme's Avatar
Default Re: Rust question (Jamez)
nice link!! thank you
Old Jun 1, 2005 | 12:17 PM
daver's Avatar
thats a fair amount of rust. a lot of it comes from the inside out, so if you were to pop off the inner panels in the trunk, you'll see it from the inside too.
The only way to fix it, is yes, get it cut out, grind and/or sandblast the metal, get new patches welded in.
the only way to make it last is to get the car rustproofed yearly. that is, get oil spays done on the insides of the panels.
Another bad spot is around the fuel outlet. yours looks ok, but it may have rust on the inside of the panel. Also look for rust coming through on the tailgate. I have found the egs to be good around the windshield and door bottoms.
I hate rust, so when i bought my eg, i made sure it was a rust free one. Had to pay 4g cdn to get it tho, 2 years ago. Its a lot easier to keep it from rusting in the first place than it is to fix it.
d
Old Jun 3, 2005 | 04:23 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: Rust question (daver)
Can some of that rust be removed by sanding then primer over it? Also can I stop this rust from continuning?
Old Jun 3, 2005 | 05:14 AM
Soccerking3000's Avatar
yea, just the surface rust you can get too, but i bet some of it goes a little deeper and its just the tipof the iceberg..
Old Jun 3, 2005 | 09:00 AM
malubawla's Avatar
you can buy a rust convertor which makes rust turn to primer from autozone, works pretty good not that bad at all
Old Jun 3, 2005 | 09:09 AM
daver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbmprelude &raquo;</TD></TR><TR><TD CLASS="quote">Can some of that rust be removed by sanding then primer over it? Also can I stop this rust from continuning?</TD></TR></TABLE>
not with just hand sandpaper. a power sanding wheel to take out the pivots and expose bare metal.
For surface rust there are primers available that are supposed to seal it if you get the loose stuff off, but sounds shoddy to me.
And as said, if the rust is coming from the inside, like a lot of this car pictured, you've got to cut it out, or it won't last
d
Old Jun 3, 2005 | 09:10 AM
daver's Avatar
or blast the outside, paint it, then rustproof the inside and take your chances..
Old Jun 19, 2005 | 12:19 PM
cbmprelude's Avatar
* B A N N E D *
do any of those special products for rust work weel in a situaction like this like that por material?
drewrund
Paint and Body
Nov 30, 2011 07:57 PM
NinjaDC2
Jan 18, 2010 10:38 PM
raukorist77
Sep 6, 2009 07:52 PM
baddboy
Sep 22, 2003 09:41 AM
AznInvasion
Feb 8, 2003 08:17 AM
