vibration during acceleration
i have a 94 teg. whenever rpms get over 2 grand, the car starts to vibrate. the vibrating gets more violent as the rpms get higher. thinking it might be the cv axle. Can anyone confirm this? Any advice to getting this replaced?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EV1L SI »</TD></TR><TR><TD CLASS="quote">Could be the CV joint/axle about to go or could just be some terrible tire balancing.</TD></TR></TABLE>
Check those axles stat.
justa question, does the vibration go away at a certain speed? i had that problem on another car and after about 70mph would go away
yea i had the same problem .. mines vibrates from 50 mph to around 70 .. the whole car vibrates .. not to mention that my rpm bounces around whenever pass 4 k ...
Recommend removing both front axles and check to see if the inner cv joints are binding or stuck. Inner cv joints can cause a harsh vibration on acceleration and go away on decel.
Rocks
15
Jul 5, 2004 04:48 PM
