people with shaved doors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic »</TD></TR><TR><TD CLASS="quote">have a 95 civic and just wanted to know where you put the actual popper? thanks </TD></TR></TABLE> Inside the door, and the linkage is attached to the same place that the outside door handle was.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic »</TD></TR><TR><TD CLASS="quote">are u talkin about the solenoid or the actural popper? is there any write ups for a 95 civic</TD></TR></TABLE>The solenoid, I have not seen any write ups on a 95 civic, but just like any car the "poppers" should go where they work the best without getting in the way
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic »</TD></TR><TR><TD CLASS="quote">yea.. thats what im asking.. where shold i put them without getting in the way...</TD></TR></TABLE>That will depend on the car, the biggest problem I see with the placement of them is they are mounted to high, they catch your clothing as you get into the car. What I would look for is a flat surface that allows the tip of the "popper" to sit square up against the door, BTW what kind of "popper do you have, the conical spring or the lever type, don't forget you can mound the "popper" on the door also, the best "homemade" ones I have seen where on a Civic, the customer had found a set of conical springs, made mounts for them so he could mount them over the doors pin switch's, he cut down the pin switch so when the door is closed so is the pin switch, and when the door is open so was the switch, it worked very well down there.
94
94
do you have pics??
I just took my door panel off... where can i put the solenoid... its a big 50lb one.. do i hook it to the vertical line from the door handle or the horitzontal line from the handle (inside the door ..the metal rod that conects the handle to the opening mechnism
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic »</TD></TR><TR><TD CLASS="quote">do you have pics??
I just took my door panel off... where can i put the solenoid... its a big 50lb one.. do i hook it to the vertical line from the door handle or the horitzontal line from the handle (inside the door ..the metal rod that conects the handle to the opening mechnism</TD></TR></TABLE>Sorry no pix, I would connect it to the same place that the outside handle is connected to now, as you will be removing it
94
94
