Camber Kits?
...from what I hear...using a camber kit on an EF can only do so much. I think if you only drop your car a couple inches, it'll correct your camber. Anything lower, gets really expensive. I think there are some upper control arms that have alot of adjustment capabilities, BUT they cost an arm and a leg.
...as for aligning the toe, it can adjusted with or without a camber kit.
hope this help
hope this help
its the toe that kills the tires not the camber, when you lower it increases toe not just camber, just get it aligned afterwards, i run with 2 degrees of neg camber and my tires dont get cooked, just rotate the tires frequently, if you want the car to turn better get 1/8 toe out, but that will wear tires
E36 Guy
16
Apr 7, 2006 09:58 AM
