Replaced tranny fly and clutch, and wont shift into gear HELP!
Old May 28, 2005 | 11:57 PM
amh0001's Avatar
Default Replaced tranny fly and clutch, and wont shift into gear HELP!
sup peeps.
We replaced my friends H22a tranny fly and clutch. (its in a 90 accord). With the car off it will shift into gears fine. But when the car is on, it wont shift into any gears. We tried bleeding the clutch line. Still wont shift into gears. We stummped. any help is appreciated.
~Adam
Old May 29, 2005 | 07:22 AM
xbn83's Avatar
Default Re: Replaced tranny fly and clutch, and wont shift into gear HELP! (amh0001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amh0001 &raquo;</TD></TR><TR><TD CLASS="quote">sup peeps.
~Adam</TD></TR></TABLE>
Check the transmission fluid???
Old May 29, 2005 | 09:42 AM
deserthonda's Avatar
does the clutch pedal feel normal?????
how did you bleed lines???
Old May 29, 2005 | 11:30 AM
amh0001's Avatar
Default Re: (deserthonda)
yes the clutch feels normal, and yes theres tranny fluid.
Old May 29, 2005 | 05:11 PM
better chk all the work you did , you might have to pull tranny out again make sure you got the right parts , make sure clutch bearing and or clutch + plate are installed properly , also chk the linkages on top of tranny make sure all is ok
Old May 29, 2005 | 08:28 PM
NAiL05's Avatar
U check if u have any fluid in the clutch master cylinder? I had the same prob and all i needed was some DOT 3 brake fluid for my clutch master cylinder re-bleed it &lt;pedal was linking fluid into car&gt; and it was fine. And if u got all that its prob something internal u messed up.
static-x
Jul 31, 2007 09:52 AM
EJK20R
May 30, 2006 09:45 AM
dc2gsr96
Apr 25, 2006 09:17 PM
reed857
11
Mar 15, 2006 08:15 PM
5po0n_Dc2
11
Feb 8, 2006 05:29 PM
