ebrake: only 2 bolts over console?
wt car are you referring to?? 96- just has those two on the front side
92-95 is on the front top unless you have an armrest (where screws are on the back also) and im unsure bout the other years
yea behind the ebrake handle is a slot where the rear of your console has two forks that dig into it to keep it down.. so unscrew the front two and then pull it up and towards the dash and youll see
