how do you remove shift boot????
Old Jul 12, 2002 | 11:43 AM
vteckiller's Avatar
Default how do you remove shift boot????
pretty self explanitary
Old Jul 12, 2002 | 11:45 AM
Larkin W.'s Avatar
Default Re: how do you remove shift boot???? (vteckiller)
If its anything like the Si which it most likely is very similar, unscrew the center console and theirs a bracket connected with bolts under it. There should only be a few bolts holding in the console. Im not sure where the bolts are on an ITR. But It was easy on the Si.
[Modified by EbboyPSi, 2:46 PM 7/12/2002]
Old Jul 12, 2002 | 11:46 AM
ITR21's Avatar
u gotta take everything apart including the entire centerconsel....thats assuming you have a type R....type R's u gotta take apart the entire center consel.....other interas just the fron half of it......just start unscrewing stuf.
Old Jul 12, 2002 | 11:49 AM
iH8RICERZ's Avatar
hrm, you selling your itr shift boot? if so..how much?????
Old Jul 12, 2002 | 11:58 AM
Rob :190:'s Avatar
Default Re: how do you remove shift boot???? (BustAhNutZ101)
just pull out the rear center console, then the front lower center console. Like EbBoy said, there's a bracket holding the boot on.
Old Jul 12, 2002 | 12:04 PM
Skunk2Civic94's Avatar
Default Re: how do you remove shift boot???? ( Rob)
it will take less than 5 mins
Old Jul 12, 2002 | 12:05 PM
Larkin W.'s Avatar
Yup, Exact same as on the Si as I suspected
Old Jul 12, 2002 | 08:15 PM
dextR's Avatar
Default Re: how do you remove shift boot???? (Skunk2Civic94)
took me less than a minute with a pair of scissors
Old Jul 13, 2002 | 12:07 AM
B2FiNiTY's Avatar
1. Pop the rectangle cover under the handbrake. Unscrew the 2 gold screws.
2. Unscrew the armrest box (unscrew 2 screws on the bottom/rear of the box) and remove
3. pull out the ashtray completely (unscrew 2 screws inside)
4. pop out the ashtray holder/cig lighter assembly
5. Unscrew 2 screws holding onto the shifter boot console and 2 more screws on the sides
6. Unscrew the shifknob
7. remove the shifter boot console and flipped it over (unscrew the 2 screws)
8. Install the new boot
Have fun
Sean DM
Honda Civic (2001 - 2005)
Dec 25, 2006 12:41 PM
deuceap610
May 27, 2004 10:25 AM
djvtoner
May 25, 2004 09:03 AM
ThisLittleSleepeR
Apr 5, 2003 05:14 PM
$pecial K
Aug 14, 2002 10:46 AM
