need help with door visors...
Old May 28, 2005 | 09:20 PM
4sup513's Avatar
Default need help with door visors...
i just bought some, dont know how to put them on... didnt com with instructions please help
its 01 teg i have the itr door visors
Modified by 4sup513 at 10:33 PM 5/28/2005
Old May 28, 2005 | 09:28 PM
.1type.'s Avatar
Default Re: need help with door visors... (4sup513)
for what car... are they oem visors?
bizzzz's Avatar
From: In the middle of a gang warzone SOCAL, CA, USA
what kind are they? and for what car? YOU NEED TO INCLUDE DETAILS FOOL!
and pix would be nice.
...some types only require clips to be put on.. others require screws..
but what may also help would be if you searched.. there are many threads just like this one.
Old May 28, 2005 | 09:31 PM
4sup513's Avatar
is this not the interga site so what does that mean its 01 teg i have itr visor
Old May 28, 2005 | 09:44 PM
ukdm crx's Avatar
Post pics of them, there pretty straight forward though and easy to put on.
Old May 28, 2005 | 09:51 PM
4sup513's Avatar
i dont have pics.. i bought them icbmotorsports they said that they are difficult to put on, not to try to put them on my self. that i will break them if i tried without instructions
Old May 28, 2005 | 10:24 PM
:jdmshmaydm:'s Avatar
This install is very very frustrating (assuming they're the Honda Access visors). There are no ITR specific visors either, they're just Honda Access for Integra.
You have to make cuts into your weather stripping on your door and mount the clips in there. You need to be very careful. I wouldn't attempt it if you're not comfortable.
Good luck searching. I don't believe there's any write-ups of how to install these on a DC Integra. I searched like crazy when I got mine and got nothing except vague instructions.
Old May 29, 2005 | 05:37 AM
bboyoracle's Avatar
Default Re: need help with door visors... (Gatecrasher21AF)
This is what you need to do......remove the top part of your weatherstripping along the actual door (only from the mirror to the 90 degree bend, dont exceed that) Mock up your visor on door frame and mark off where the holes on the visors meet the door frame with a highlighter or something.
Now the visors come with two screws. The Integra should already have a hole drilled by the 90 degree bend, so one is eliminated. You'll need to drill a hole next to the mirror on top of the door frame. It should be the first hole you marked closest to the mirror. Now the bulk of the work is done.
I believe there will be three more holes(I could be wrong) on the visors. You'll need to cut off a section of the weatherstripping NOT THE PART THAT SHOWS when you put the weatherstripping back on but the part underneath. Just cut a inch section around each dot that you marked. I dont know if you have the hardware, but here you will use two plates. They work off each other and snap into place two hold into the door frame. The reason you cut the weatherstripping is so you can allow it to go back into place with out any sections sticking out( bc of the plates being there now).
Now you are almost done. There should be one hole on the visor right next to where it says "INTEGRA" That will not be a screw. Its a little cap that holds that section in place. So I believe you already marked that. Now cut DEEP, with a razor, about a half an inch above and below the mark into the weatherstripping. There should be one certain plate that you use for this section. Just slide it in.
Now put the weatherstripping back on tighten all the screws onto the visors and sit back and enjoy!!!!
I know it seems like a lot but it honestly isn't. It took me 3 hours to put them on. The instructions come in japanese so I had to figure it out just by the pictures (and it isnt exactly step-by-step) The only reason it took me 3 hours was because 2 1/2 of those hours were spent trying to figure it out. It took less then 30 min to put on the other side once i figured it out.
If you have any questions let me know. Good Luck.....peas.
Modified by bboyoracle at 4:43 PM 5/29/2005
Old May 29, 2005 | 10:36 AM
lightsleeper's Avatar
Default Re: need help with door visors... (bboyoracle)
https://honda-tech.com/zerothread?id=632263
this might help....its for civics though...not sure how the integra ones are set up though so this link may not help at all.....
bryant
Honda S2000
Jan 15, 2005 03:37 AM
Mr.Fairlady
Jan 2, 2004 06:26 PM
DarthLuder
Mar 7, 2003 04:53 PM
94civicx
Jul 23, 2002 08:23 PM
2kGSboi
Sep 10, 2001 12:31 PM
