NEED HELP removing stuck on H&R 5mm spacers from hub =l
Old May 28, 2005 | 07:57 PM
jdmspoonitr's Avatar
Default NEED HELP removing stuck on H&R 5mm spacers from hub =l
OK well I had to run 5mm h&r spacers to clear my calipers, but now I'm switching wheels and they don't come off. I have tried wedging things between and prying it off, but it fits too tight around the hub. So basically I can fit a knife in there and then a flat head, but if i pull to hard on the flat head I will break the spacer.
Anybody got any ideas? This is aluminum. And it is flexing when I try and pull on it. I guess if I break em I'm only out 70 bucks, but still I'd like to be able to use em. So if anybody has any ideas let me know. TIA
Old May 28, 2005 | 08:20 PM
migs's Avatar
Default Re: NEED HELP removing stuck on H&R 5mm spacers from hub =l (jdmspoonitr)
all i could suggest is using wd40 on it to loosen it up around the hub then then use a pick and go around it
Old May 28, 2005 | 08:22 PM
uNF$@#!'s Avatar
Default Re: NEED HELP removing stuck on H&R 5mm spacers from hub =l (migs)
liquid wrench - let it soak and use it numerous times.
then take a hammer, and wrap cloth around it, and lightly tap.
should come off
Jhonny Ricer
Mar 28, 2007 01:46 PM
toguemaster
Suspension & Brakes
May 27, 2006 01:25 PM
ultimatehonda
Dec 11, 2003 08:39 PM
lshobo
Mar 14, 2003 09:59 AM
rolow
Oct 28, 2002 09:20 AM
