tried seraching explain to me "bore" and why is it nesscary to?
Old May 28, 2005 | 07:41 PM
Gant's Avatar
Default tried seraching explain to me "bore" and why is it nesscary to?
hey guys
just wanted to find out , might be shopping for pistons i remember discussing it during school but that was alonnnnng time ago.
standard bore is what for a d16z6? when i get a piston why would i want to get a .20 bore why not get a piston with a stock bore? is it cuase u gotta bore out the cylinder for the new piston? so now ur cylinder wont be in stock "specs" so u have to get a little bit bigger bore piston?
please enlighten
-chris
Old May 28, 2005 | 07:54 PM
Rocket's Avatar
Default Re: tried seraching explain to me "bore" and why is it nesscary to? (Ba4)
You cylinder as is may be out of round and have some taper. Rings don't seal well when the cylinder is out of round.
Properly boring the cylinder will make the cylinder perfectly round and straight. Then it should be finished honed to size to prep the cylinder surface for the rings.
Rottler or Kwik-way are common boring machines used in boring cylinders.
After that your cylinders honed they need to be washed with hot soapy water 3 times and then wiped down with ATF, acetone or lacquer thinner soaked rag till you see no residue. Only then you can think about installing the pistons.
Old May 28, 2005 | 08:02 PM
Gant's Avatar
i c so whats a good piston bore to get? is .20 enough to bore out even a pretty out of round clyinder wall?
Old May 28, 2005 | 08:10 PM
Rocket's Avatar
Default Re: (Ba4)
Yes. 0.020 (0.50mm) over is plenty to ensure roundness.
HopperIsMyCar
Dec 7, 2011 03:50 PM
downeyballz
Jul 6, 2008 01:21 PM
qazaq
Jul 14, 2007 04:20 PM
jennsGSR
Aug 17, 2006 06:12 PM
seako_916
May 19, 2004 09:28 PM
