What octane of gas do you guys reccommend for '93 Preludes?
Old May 28, 2005 | 06:47 PM
SephCast's Avatar
Default What octane of gas do you guys reccommend for '93 Preludes?
I just got a '93 Prelude S for 2700. I'm just wondering if you guys recommend low, medium, or high octane. Is it really necessary to get high octane for a prelude?
Old May 28, 2005 | 07:12 PM
dreams190's Avatar
im not sure about the S model but I know for the Si and VTEC, you wanna use high grade because the compression is kinda high.
Old May 28, 2005 | 07:15 PM
AndyD's Avatar
Default Re: What octane of gas do you guys reccommend for '93 Preludes? (SephCast)
Prelude S needs 87 octane. Don't use any higher.
Old May 29, 2005 | 03:46 AM
high_revs's Avatar
i would use 89 on a S since in jersey thats the lowest usually....but on my Si i use 94 :D
Old May 29, 2005 | 04:18 AM
rice-racer Uk's Avatar
Default Re: (all mOtor h23)
Hi guys, i dont know if your cars are set up different from ours ie European but Over here all Vtec hondas require min 95 octane fuel and Jdm cars require min 98 octane. As i say that is providing Honda dont change the state of tune for the American market due to your standard pump gas being a lower octane rating than ours, our standard pump fuel is 95 and the high grade stuff is 98. Presonally i find that although not absolutly neccecery using the hgh octane stuff gives my higher mpg and the car is more responsive. On the plus side you guys have cheap as chips pump gas wheas we currently pat 087.5 pounds sterling per litre not gallon !
Old May 29, 2005 | 07:29 AM
high_revs's Avatar
yeah cars in europe also perform better then the cars in us, because here we have shitty gas. most states only offer like 91, but nj is lucky enough to atleast get 94 but its expensive as sh*t.
Old May 29, 2005 | 07:41 AM
dreams190's Avatar
damn, so even though I'm using 93 in my JDM h22, it still should be higher octane?
Old May 29, 2005 | 07:44 AM
01 LudeDude's Avatar
98 octane at the pump? Do they use the same method to determine octane as we do in the states? It would be awesome to be able to grab 98 at the pump, not that most of us need it.
Old May 29, 2005 | 08:42 AM
LudeBehavi0r's Avatar
87 is fine for an F22, I think using higher octane would be a waste.
My Si manual says use the highest possble but I try to run 89 most of the time. The compression isnt that high and I cant always afford the 93. When i do my h22 swap im using 93 all the time tho.
Old May 29, 2005 | 08:53 AM
crdcz03's Avatar
Fortune Cookie Member
Default Re: (Ludebehavior85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludebehavior85 &raquo;</TD></TR><TR><TD CLASS="quote"> I cant always afford the 93. .</TD></TR></TABLE>
mid grade is usually $.10 less than premium... meaning you save about $1.00 for each 10 gallons of gas. you will put usually 12-13 gallons on an empty tank. if you cant afford that extra dollar then you need a new job
Old May 29, 2005 | 08:56 AM
Rad Racing's Avatar
Bart Taylor Look-alike
Default Re: (01 LudeDude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01 LudeDude &raquo;</TD></TR><TR><TD CLASS="quote">98 octane at the pump? Do they use the same method to determine octane as we do in the states? It would be awesome to be able to grab 98 at the pump, not that most of us need it. </TD></TR></TABLE>
In Cali certain Unocal 76 stations have 100 octane at the pump. I only use race gas so I rarely use it at the pump, but about 5-6 years ago it was a big help on the way to go street race or to a track.
Old May 29, 2005 | 09:13 AM
monalisa overdrive's Avatar
i think their rating system is slightly different over there.
Old May 29, 2005 | 10:11 AM
homesauce's Avatar
Default Re: (monalisa overdrive)
yes, europe has a different octane rating.
Old May 29, 2005 | 10:23 AM
ckyskater733's Avatar
yea theyre different rating systems...read it in scc lol.
but, i think the manual that came with the preludes said to use at least 91 octane for si and vtec motors, but you can use 87 for the prelude S
Old May 29, 2005 | 01:15 PM
eMpAtHy's Avatar
h23+h22=require 91 octane i believe
for the f22, use 87.
Old May 29, 2005 | 01:35 PM
Default Re: (crdcz03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 &raquo;</TD></TR><TR><TD CLASS="quote">mid grade is usually $.10 less than premium... meaning you save about $1.00 for each 10 gallons of gas. you will put usually 12-13 gallons on an empty tank. if you cant afford that extra dollar then you need a new job</TD></TR></TABLE>
Good point.
I guess its not that I cant afford it, more so that I dont think a stock h23 or F23 needs 91+ octane. I think 89 is sufficient enough for sub 10:1 CR. I might get flamed for this...but thats my two cents and I know 89 octane isnt gonna blow my engine up, retard timing so much that I dont have power, or cause detonation.
Old May 29, 2005 | 02:04 PM
Chronic H22's Avatar
the vtec's have a little note right by your speedo that says "Premium unleaded fuel only" and premium is usually the highest octane before you get into the race gasses...
Old May 29, 2005 | 02:14 PM
Yea, we know that....what was your point?
Old May 29, 2005 | 03:37 PM
eMpAtHy's Avatar
Default Re: (Chronic H22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronic H22 &raquo;</TD></TR><TR><TD CLASS="quote">the vtec's have a little note right by your speedo that says "Premium unleaded fuel only" and premium is usually the highest octane before you get into the race gasses...</TD></TR></TABLE>
hrmm, i just have a stock odometer and mine says "premium unleaded fuel only".
Old May 29, 2005 | 03:57 PM
You guys say that using high grade ie higher than 89? is a waste this may be true but our cars come from the factory with a sticker inside the filler cap that reads min 95 octane only so based on that i assume the cars require it. Also as i said i get better mpg with the high octane stuff so it works out cheaper in the long run. In answer to your question about whether we use the same method to determine the octane rating i havent a clue. i believe the fact that you guys have lower octane fuel is that due to the fact that you guys live in a much hotter country so a higher octane fuel would evaporate far too quickly (for example while the car is parked or when you remove the filler cap) therefore you would get shitty mpg. As i say im not 100% on this it's just a theory.
Old May 29, 2005 | 03:58 PM
steveobb4's Avatar
Default Re: (eMpAtHy)
If you use a higher octane than needed then your not getting complete combustion. Octane= the fuels resistance to ignite/the higher the octane #=more stable fuel.
Old May 30, 2005 | 11:10 PM
Default Re: (steveobb4)
ludebehavior you guys are arguing about what level os gasoline to use. Im saying that in the Vtec's, it says "premium unleaded fuel only". Premium is usually the gas that has the higherst octane on the pump (87,89,91) hence you would always use the 91. If honda recommends it then my guess is you should do it lol. Its way better on your engine too.
Old May 30, 2005 | 11:17 PM
The Phil's Avatar
I don't do everything honda reccomends, and it hasn't killed me yet. I don't put only genuine honda MTF in my tranny, i use syncromesh. I don't use honda oil or oil filters. I don't replace the "replace every time its removed" bolts every time. Their reccomendations are just that: reccomendations.
You're right about the gas though. I run premium in my vtec prelude just because that's what it says to use and its not that much more expensive.
Old May 30, 2005 | 11:29 PM
h8trix's Avatar
Default Re: (ckyskater733)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckyskater733 &raquo;</TD></TR><TR><TD CLASS="quote">yea theyre different rating systems...read it in scc lol.
but, i think the manual that came with the preludes said to use at least 91 octane for si and vtec motors, but you can use 87 for the prelude S</TD></TR></TABLE>
i second that w/ 94 helms
Old May 30, 2005 | 11:46 PM
budget's Avatar
Default Re: (h8trix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h8trix &raquo;</TD></TR><TR><TD CLASS="quote">
i second that w/ 94 helms</TD></TR></TABLE>
i third that
