ok to spray carb cleaner around eacv
Old May 28, 2005 | 06:02 PM
SNsLude's Avatar
Default ok to spray carb cleaner around eacv while intact?
hoses are stuck on there damn good... tried sticking a flathead in the hose heads... nothing... any ideas? if not can i just spray the carb cleaner right on the eacv without taking the whole unit out? any harm in that or to the units around it? tia
Modified by SNsLude at 7:35 PM 5/28/2005
Old May 28, 2005 | 07:30 PM
TimeRacer's Avatar
Default Re: ok to spray carb cleaner around eacv while intact? (SNsLude)
You'll be fine. Just make sure you either a) replace those o-rings or put a gasket marker on those o-rings to ensure that they seal up when you put it back. Just for future reference carb cleaner is usually fine for anything along the intake track.
Old May 28, 2005 | 07:35 PM
SNsLude's Avatar
Default Re: ok to spray carb cleaner around eacv while intact? (TimeRacer)
hey thanks man... no additional o rings around or a gasket to put on for that matter... should be ok like that temporarily yah?
Old May 28, 2005 | 09:34 PM
TimeRacer's Avatar
should be okay, but if you get a hunting idle it's because of a leak. So don't freak out if it does.
Old May 28, 2005 | 11:10 PM
integra15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SNsLude &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by SNsLude at 7:35 PM 5/28/2005</TD></TR></TABLE>
Use a pair or needlenose pliers and gently twist the hoses off, works much better than a screwdriver
ericstambaugh07
Mar 13, 2007 05:10 PM
SimplyTron
Jan 26, 2006 08:19 PM
ULTRA911
Mar 4, 2003 10:00 AM
morepoop4u
Jun 23, 2002 08:00 PM
GruvyTune
Jul 30, 2001 12:44 PM
