ECU code.. 4 long pules and then a quick one or it could be 5 long and then it just shut off quickly
I threw a light last night. I pulled the code today and it's 4 pulses and the last one is kinda quick. I'm not sure if thats normal for the last one or not or if it's the second number.
can sombody give me the codes for 5 and 41 (assume it's 41)
Thanks.
Thanks.
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
if its 41 its o2 sensor heater
I confirm. It should keep going over the code, it wont stop the last one quickly if it meant a long flash..
well the oc2 sensor heater wouldnt cause me to fail smog would it. This should only be on until the oc2 sensor is heated then it doesnt come back on right?
If the check engine light is on while you are doing your smog test, the person doing the test will fail you.
yup, four long pauses and one fast obe would be primary o2 sensor -heater DoEs AnYoNe KnOw WheRe I CaN GeT SoMe StRObE LiTEZ AnD LiGhT uP WiNdShiElD NoZzLeS?? up! the blinks will not just stop i dont think....i think it keeps reading the same code over and over again...cherck your o2
yes the code does loop and loop. did i say it stoped somewhere? oh well anyway i asume i would have to replace the hole o2 sensor. The check engine light wasnt on when a smoged it. I failed emittions not he visual.
why did you fail emssions?? oh and i looovveee te jesus and magic thing!
[Modified by cali-r, 8:45 AM 2/8/2002]
Was running too rich, i passed the 25 mph test but failed the 15 mph test.
It's true......
Hmmm i feel a flaming religious thread comming on.
[Modified by SystemGSR, 11:38 AM 2/8/2002]
bumthology
Oct 5, 2004 03:18 PM
SystemGSR
Jun 3, 2002 09:56 PM
