Do I need these Vacuum parts to have my car runnign right?
The red cirlces are what i dont have...
and the green one isnt there on my jdm h22 manifold, but theres a flat plate covering that hole.
BTW im running a P13 in a EG with a JDM H22
well the evap canisiter and purge solinoid you don't really need, its just there to pull fumes out of the tanks.. though you should throw a code ( i think? ) if the ecu can't sense that the evap purge solnoid is opening. the egr stuff that is missing will throw a code.. and don't worry about the intake controle solenoid, thats just for the secondary intake track on the resonator, and the ggreen you circle is just a air valve that at starting time allows more air to pass to help the car start.. its not a nessesity, i removed mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoOHiGH »</TD></TR><TR><TD CLASS="quote">so i would need EGR control solenoid valve and EGR vacuum control valve?</TD></TR></TABLE>
the p13 with definatlly throw a code if it doesn't detech the egr is moving and functioning
now shes throwing a code 10 (IAT).... funny thing is it hooked up right.
EDIT - IAT was unpluged. now the solid CEL is back.
Modified by SoOHiGH at 6:52 PM 5/28/2005
1991civicd16z6
Northern California (Sales)
Sep 17, 2008 04:09 PM
