Smoke from tubo... white / blue.
Old May 28, 2005 | 12:06 PM
T--Rex's Avatar
Default Smoke from tubo... white / blue.
Ok, just put it in... it is not all the way set up, I was just testing to see how it ran, oil lines, exhaust, wastegate set up. When i rev it up and the turbo spools it is ok... a little bit of smoke. When i let off the gas and the rpms drop it blows alot of smoke. Any ideas what that could be? do I have a crap turbo? Any thoughts?
Old May 28, 2005 | 12:10 PM
pv2dickman's Avatar
Default Re: Smoke from tubo... white / blue. (Matrix_Zero)
you could have bad seals in your turbo.. that is just opinion
is there oil coming out of the turbin side?
Old May 28, 2005 | 01:59 PM
T--Rex's Avatar
Default Re: Smoke from tubo... white / blue. (pv2dickman)
no.
Also, The oil return line is only about 4 inches beause the turbo sits so low. How do I get new seals? Any suggestions?
Old May 28, 2005 | 07:04 PM
pv2dickman's Avatar
well if there is no oil comin out.. then your turbo seals are good
and my oil return is about 5 inch.. that doesn't really matter.
i am assuming that the smoke was coming out of the downpipe..
did your car smoke without the turbo on.. ??
Old May 29, 2005 | 11:24 AM
T--Rex's Avatar
Ok, no oil from the turbine side, but smoke from the exhaust side. I did not have smoke coming out before.
lookout22
May 17, 2009 07:37 PM
GReddy_Civic
Aug 11, 2008 11:42 AM
silverboost
Dec 13, 2005 12:44 PM
boostedlude3g
Apr 16, 2003 07:08 PM
dynomax27
Nov 1, 2002 02:40 PM
