what is a p08-2 head?
Old May 28, 2005 | 05:40 AM
ssbpturbohatch's Avatar
Default what is a p08-2 head?
my buddy has a p08-2 sohc vtec head and we are not sure which head it is(z6,y8,vx, jdm d15b). i searched but could not find a definite answer to this aside from the usual "it's a soch vtec head" kind of answer which i already know. any info or links to help me out would be great. If anybody knows specs and/or differences in the head from other heads i would love to know these specs.
Thank you for any help,
Aaron
Old May 28, 2005 | 07:12 AM
The DX Rex's Avatar
Default Re: what is a p08-2 head? (ssbpturbohatch)
maybe the jdm d15b?
i kno they use a p08 ecu so
Old May 29, 2005 | 07:14 PM
chrisw85's Avatar
P08 is the head off a JDM D15B sohc vtec motor. I do not know what the "xxx-2" is there for, but p08 is D15b vtec head. Very similar to a D16Z6 head but has more aggressive cams from what I read. The head with the 'silver' valve cover is 95+ and the black valve cover was on pre-95 models; both are pretty much the same.
http://asia.vtec.net/article/d15b/ thats some more info on the D15B.
also, D15B is jdm sohc vtec
D15B7 is the USDM sohc "DX" motor as far as I know.
Old May 29, 2005 | 08:14 PM
slotec's Avatar
Default Re: what is a p08-2 head? (chrisw85)
it could easily be a stock z6 head ive seen many z6 heads with p08 on them, but i also have a d15b and it says p08 ill check and see if theres any numbers after the p08
Old May 29, 2005 | 09:09 PM
canis's Avatar
Default Re: what is a p08-2 head? (slotec)
ive seen both, ive seen guys that have got the po8 on the D16z6 and the d15, so i have no clue, from what ive seen there the same damn thing, but i dont know ****..
Old May 29, 2005 | 09:33 PM
blackeg's Avatar
Default Re: what is a p08-2 head? (canis)
p08's are the casting for z6 and d15b heads. this one is a 1992. im not sure how to check which one it is..maybe take the cam out and measure the profile, cause they are different
Old May 29, 2005 | 10:24 PM
slotec's Avatar
Default Re: what is a p08-2 head? (blackeg)
yea the cams are different, everything else is pretty much identicle even the intake manifold and dizzy but exhauzt manifold is different
Old May 29, 2005 | 10:39 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">maybe take the cam out and measure the profile, cause they are different</TD></TR></TABLE>
Wide VTEC lobe =D15B, Narrow VTEC lobe = Z6.
Old May 30, 2005 | 09:30 AM
Default Re: what is a p08-2 head? (Jim Truett)
thank you for all the replys, i hope it helps my buddy out
frankeelv
Mar 14, 2014 02:22 PM
2DoorBandit
May 14, 2006 10:08 PM
Ding
13
Aug 19, 2005 01:52 PM
ssbpturbohatch
May 30, 2005 09:31 AM
BMacls
Jul 26, 2003 04:03 PM
