PLZ Help! (HID)
Old May 28, 2005 | 01:51 AM
dmckrazy45's Avatar
Default PLZ Help! (HID)
Okie... I just installed 8000K HID's for my 98prelude... I ordered the H1 Bulb size.. they seem to be way longer then the stock bulbs...??
No matter how much i wiggle arund with the bulbs... it seems to be aiming WAY to high..
help~~~~~~~~~~
Old May 28, 2005 | 06:11 AM
prelude1897's Avatar
Default Re: PLZ Help! (dmckrazy45)
Aim your headlights themselves downward....There are 2 adjusters on each headlight
Old May 28, 2005 | 06:53 AM
st3alth's Avatar
Reflector housings like the preludes etc, the cut offline will be poor and there will be stray light going all over the place which can glare oncoming traffic. HIDs for reflector housings isnt recommended IMO.
Old May 28, 2005 | 07:19 AM
mraza's Avatar
Yea I had the same exact problem with my 98 prelude, had to angle it all the way down with the adjusters. Its still pretty bright but not as much.
Old May 28, 2005 | 07:31 AM
Default Re: PLZ Help! (mraza)
The best way to fix this problem is to put Projectors into your headlight housing
Old May 28, 2005 | 07:49 AM
iwhichisme's Avatar
does anyone have a write-up on how to install those projectors into the 5th gen headlights? Also, which would be the best fit as far as the projectors are concerned.
Old May 28, 2005 | 07:52 AM
h8trix's Avatar
Do a real retrofit. I saw a writeup for 5th gens on either preludeonline.com or hpoa.org
Learn: http://www.hidplanet.com/forums/
Buy: http://www.hidplanet.com/main.html
Old May 28, 2005 | 09:14 AM
Default Re: PLZ Help! (iwhichisme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a write-up on how to install those projectors into the 5th gen headlights? Also, which would be the best fit as far as the projectors are concerned.</TD></TR></TABLE>
If you need parts to do a Retrofit for your car, I have everything you need for sale
https://honda-tech.com/zerothread?id=1249677
Old May 28, 2005 | 11:59 AM
4LugR's Avatar
Default Re: PLZ Help! (prelude1897)
so the best fit would be the BMW E55 projector??? it loooked like it fit pretty damn snug in there.
Old May 28, 2005 | 12:05 PM
foshizllmynizl's Avatar
Default Re: PLZ Help! (AEMPrelude916)
you could also get a casper shield and block off the underneath of the HID bulb ... search on HID forums, they have usefull information there.
Partizan
Jan 8, 2011 08:58 PM
gtec8285
Jun 22, 2008 07:45 PM
turbo'd
Apr 26, 2005 10:22 AM
ChaseIntegra
Jan 19, 2005 05:19 AM
itr1244
Mar 29, 2003 03:40 AM
