helmet question
Old May 27, 2005 | 11:08 PM
jonoknut's Avatar
Default helmet question
I dropped my friends helmet from about 24" inches off the ground onto the street. There minimal chip in the helmet from it. He told me it is garbage and need to buy a new one. I understand if you are in a crash and it is cracked or beat up, but is this neccessary to replace? Thanks.
Old May 28, 2005 | 12:13 AM
Odiedogcx's Avatar
AIRBORNE
Default Re: helmet question (jonoknut)
It depends. Send it back to the manufacturer, and they can do a test on it to see if it's still road worthy. What brand helmet it is?
Old May 28, 2005 | 12:48 AM
bustdesenuts's Avatar
2 feet isn't going to do much to the helmet.
Old May 28, 2005 | 01:37 AM
Nidius's Avatar
Default Re: helmet question (bustdesenuts)
If it does, it's not much of a helmet then.
Old May 28, 2005 | 03:59 AM
Ohlias's Avatar
Default Re: helmet question (NidStyles)
THe only way yo find outis to have it x-rayed. It could have caused enough stress in the outer shell to affect the way the helmet will react in a real crash. Especially if the location of impact is the same.
If it's Shoei or Arai, I belive it's a free service for 5 years, you cna send it to them (at your cost) and they will ship it back after the check it for free (at their cost I think).
Good luck.
Old May 28, 2005 | 06:28 AM
all8280bcc's Avatar
Default Re: helmet question (Ohlias)
well from what i understand if it is an old helmet you are supposed to replace helmets every three years.
Old May 28, 2005 | 02:14 PM
jonoknut's Avatar
Default Re: helmet question (all8280bcc)
the helmet is only a few months old i believe.... and it was $480 so i cant imagine it was a cheap one.....
Old May 30, 2005 | 05:34 PM
Wicker Man's Avatar
The way I was explained about this helmet dropping issue was that the outer shells of helmets are just multiple layers of thin plastic which have a very small spacing between them. When you drop it at "such and such" height then those plastic layers will compress like they are supposed to in a crash case and there will be no gap between the layers. Without this gap it is possible for the impact to crack the plastic which could cause an unsafe lip and catch. The main reason for the outer shell is to allow your head to slide without any stress on it, so if there is a crack that could catch and turn nasty.
So basically if the layers are compressed then the helmet could crack and that could be bad. From what I heard Ohlias is correct in saying you can send them back to have the helmet tested out. Most of the time due to safety regulations they will just come back stating they are unsafe because you could imagine the lawsuit if they send a helmet that has been dropped back and it turns out unsafe.
I was explained this by the MSF course teachers and I would agree with it because it is logical. Sorry dude but it looks like you might need to be buying him a new helmet. I wish I could tell you otherwise.
Old May 30, 2005 | 07:18 PM
00yamahaR6's Avatar
Default Re: helmet question (Wicker Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NidStyles &raquo;</TD></TR><TR><TD CLASS="quote">If it does, it's not much of a helmet then. </TD></TR></TABLE> i agree
poison
Mar 23, 2006 06:45 PM
DeLiRiOu5
Honda Motorcycles
23
Apr 11, 2004 07:05 PM
VTECAcuraGSR
Oct 21, 2003 08:40 AM
zijiejijeijrkjk
Apr 3, 2002 03:50 PM
neof69
Dec 30, 2001 05:46 PM
