Valve job... Now clatter
Old May 27, 2005 | 10:37 PM
shbrown's Avatar
Default Valve job... Now clatter
I got a valve job done on my D16z6 head before I set up the mini-me... Now it is running, it has a loud valve clatter. I have tried to adjust the valves, but no change. Will the valves seat and quiet down? I have not driven it yet... Or maybe I screwed up the valves on the install? I don't have a compression meter to test...
What do you think? Drive it and hope it gets quieter? or what else??
-S
Old May 27, 2005 | 10:45 PM
mr. carpenter's Avatar
Default Re: Valve job... Now clatter (shbrown)
check the timing. if it's off then you might get a tick.
Old May 27, 2005 | 10:53 PM
shbrown's Avatar
Cam timing seems OK. I need to mess with the dizzy a bit, and file a bit off to retard it a bit, the ignition timing is a bit advanced. Maybe 5 degrees or so. Would this make it tick?
Old May 28, 2005 | 01:00 AM
blah13's Avatar
Default Re: (shbrown)
yes, 5 deg of advance is way too much, bring it back to 16-18. The chatter you hear is probably detonation.
Vladglad
29
Jan 3, 2014 06:05 PM
crxaddikt
Mar 8, 2013 08:06 PM
shbrown
May 27, 2005 07:58 AM
euG3dc2r
Feb 23, 2005 03:45 AM
Trbospnkr
Jul 3, 2003 07:25 PM
