steering wheel swap - 90 lude/ 95 civic
Old May 27, 2005 | 06:39 PM
mountaindewguy's Avatar
Default steering wheel swap - 90 lude/ 95 civic
ok i wanna black interior..i kinda like the looks of the 90 honda prelude steering wheel...is it a direct bolt on to the 95 civic ex coupe?
if not, how can i get it on?
Old May 27, 2005 | 06:50 PM
brockscivic's Avatar
Default Re: steering wheel swap - 90 lude/ 95 civic (mountaindewguy)
ive never seen the two steering wheels off and compared side my side but in my mind the only thing that would stop it if everything else worked out would be the airbag and SRS
Old May 27, 2005 | 09:08 PM
13BT's Avatar
ive had a 90 prelude in my 94 civic hatch. i would suggest getting either an aftermarket wheel or a JDM wheel.
the prelude wheel is a direct bolt on...but the bad thing about it is that you cant put your column surround cover on with it. It has to sit so close on the spline that when you hold the wheel normally and take a turn your knuckles end up hitting the switches.
and make sure you find a write up on how to disable your SRS so your airbag wont pop in your face.
Old May 28, 2005 | 03:52 PM
ant123's Avatar
why dont u juss get an aftermarkert sterring wheel
Old May 29, 2005 | 06:35 AM
Default Re: (ant123)
because i can get it for free....therefor questioning the fitment
boostedteg1203
Feb 19, 2010 05:02 PM
driveslow
Dec 9, 2008 04:41 AM
marquisdee1018
Sep 13, 2006 05:27 PM
Hondasaurs
Jan 23, 2003 09:15 AM
