IAVC Problems
Old May 27, 2005 | 04:11 PM
crx1racing's Avatar
Default IAVC Problems
My idle used to surge up and down, but I took off the IAVC which was making a loud humming noise, found nothing wrong, switch the coolant line to allow better flow, it stopped surging the idle, but still hums loudly. Any suggestions?
Old May 27, 2005 | 04:25 PM
crx1racing's Avatar
Default Re: IAVC Problems (crx1racing)
Nobody know? ****. Maybe it'll blow up or something so i can replace everything again, till then screw it, just drive...
Old May 29, 2005 | 04:15 PM
crx1racing's Avatar
somebody asked me if I had taken off the lid to make sure everything was tight. The bottom piece that bolts on with the coolant lines going to it doesnt have anything inside of it, it just allows coolant to flow through to cool it off. The screw on the side of it was taken off and the spring is fine, cant get to anything else. Put back together and had to adjust it to idle properly again, still humms...help
Old May 29, 2005 | 04:29 PM
91 HONDAsaurus rex's Avatar
What engine is it. B16a's have FITV problems and you just remove that and screw back in the plastic thing that holds a spring in it. Also your IACV could be dirty just use some throttle body cleaner and spray it in the IACV. You could also have low voltage going to it, check it with a voltmeter.
Old May 29, 2005 | 04:36 PM
crx1racing's Avatar
Default Re: IAVC Problems (91 HONDAsaurus rex)
Its a D16A6 that I dropped into a 90 CRX DX and did the dpfi to mpfi conversion on it. I dont have a multimeter, only a voltage tester (lights-up a fuse). I blew it out with an air compressor.
neldogg
Nov 17, 2007 03:52 PM
92HB_HB
Dec 7, 2006 02:50 AM
deeweezy187
Dec 3, 2005 08:50 PM
BLUE EH3
May 17, 2005 03:10 PM
LsTurbo91
Dec 18, 2001 12:23 AM
