distributor rotor rotation
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz »</TD></TR><TR><TD CLASS="quote">The same way as the engine. Looking at it straight on, clockwise.</TD></TR></TABLE>
straight on from the passenger side of the car
the same way the cam shaft rotates...
j/k... look at the engine belts.. i believe they go counter if you're looking from the driver side to passenger..
but if you take the cap off then i believe they go clockwise.. heheheheh
i might be wrong...
i might be wrong...
Just to help everyone who needs to know this. The rotor has a phillips screw that is tightened to hold it on to the distributor, which is spun by the cam. Therefore if you look at it straight on it will spin clockwise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz »</TD></TR><TR><TD CLASS="quote">Just to help everyone who needs to know this. The rotor has a phillips screw that is tightened to hold it on to the distributor, which is spun by the cam. Therefore if you look at it straight on it will spin clockwise.</TD></TR></TABLE>
this man speks the truth
mellowman164
Jan 12, 2014 10:59 PM
civicproblems
Jan 6, 2005 04:05 PM
typesguy
Dec 3, 2003 08:56 PM
