RPM Drops at 5200
Old May 27, 2005 | 12:18 PM
digkhangboyz's Avatar
Default RPM Drops at 5200
i am not sure what is going on, i need help
i recently install turbo on 99 honda prelude
my rpm drops at 5500..
i change pretty much everything that i can think of
fuel system( fuel rail-fuel pressure-)
Distributer
Old May 27, 2005 | 02:12 PM
2lude4u's Avatar
Default Re: RPM Drops at 5200 (digkhangboyz)
It could be any # of things. Describe what's happening a little better. How? Any sounds? is your check engine light on? etc.
Old May 27, 2005 | 04:35 PM
allmotor99lude's Avatar
have you messed with a vtec controller or anything like that? if the solenoid isnt hooked up properly it wont switch cams and will choke you out around that rpm
Old May 27, 2005 | 05:45 PM
cpforyou's Avatar
Default Re: RPM Drops at 5200 (allmotor99lude)
Did you push you clutch in, and thus it dropped?
Old May 27, 2005 | 07:02 PM
Shakes's Avatar
space cadet
Default Re: RPM Drops at 5200 (cpforyou)
do the RPM's drop and then go back up? if so sounds like your clutch is going out.
Old May 27, 2005 | 08:54 PM
cpforyou's Avatar
Default Re: RPM Drops at 5200 (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">do the RPM's drop and then go back up? if so sounds like your clutch is going out. </TD></TR></TABLE>
That's very true! When my clutch went out, it would not grab above 4000RPM for me, unless I took it easy. The disc did not make full contact to the flywheel for mine because it dug a groove into my flywheel.
Tytank7
Mar 5, 2008 06:05 PM
STEVE-O7
Oct 10, 2007 05:18 PM
Mr.Motion
Honda S2000
Apr 2, 2006 10:16 PM
JimmyAtlantis
Dec 8, 2005 12:41 PM
xkpjokerx
15
Dec 1, 2004 02:39 AM
