Idle Noise. A/C related
Old May 27, 2005 | 12:09 PM
Kolijian's Avatar
Default Idle Noise. A/C related
Ok!
Today I noticed for the first time, a loud rattling type noise with the car in neutral.
I turned down the radio and could hear it clearly, once i turned off the A/C the noise went away, turned it back on, the noise re-appears.
However, once i engaged the clutch to move off, the noise went away.
What could this be or related to?
Old May 27, 2005 | 07:03 PM
grnlion's Avatar
Default Re: Idle Noise. A/C related (Kolijian)
if there was just noise with the a/c on/off then I'd say it was the magnetic clutch on your a/c compressor. Since it goes away when you press the clutch in not too sure. Is there no noise at all when driving normal, or slow?
Old May 27, 2005 | 10:01 PM
CPR's Avatar
CPR
I had the same exact issue! The dealership attempted to fix it twice. The 1st time, they replaced all my tranny bearings. When that didn't work, they replaced my clutch/fw/pressure plate. That got rid of the issue for a while but I think it's back again.
UpAndComin
Transmission & Drivetrain
Feb 17, 2009 08:25 AM
TegraD
Sep 20, 2008 10:24 PM
battleREADYb20
Oct 8, 2006 12:10 PM
DXH
Oct 1, 2006 11:55 AM
