d16y7 Tranny Synchros
Old May 27, 2005 | 11:40 AM
ineedboostbad's Avatar
Default d16y7 Tranny Synchros
I have a 97 cx, w/100k mi.. Grinds into 3rd, stubborn in first and reverse from a dig...
What is the cheapest fix for the synchros?? Is Gearworks. 1-909-476-7252 the cheapest aftermarket solution?
-James
Old May 27, 2005 | 07:35 PM
Default Re: d16y7 Tranny Synchros (97GSR Hatch)
I'm sure lots of people have had this problem, found nothing via search...
Mista Bone's Avatar
D Tranny Guru
how do you know it is the synchro??????
I'm betting worn motor mounts or a bent 1-2 shift fork.
Old May 27, 2005 | 07:38 PM
Default Re: d16y7 Tranny Synchros (Mista Bone)
worn mounts may have caused the problem, but when sitting still it is stubborn at times to get 1st gear. If I shift to third above 4k rpm, no matter how long I wait, it still grinds.
If you can recomend a good cheap solution for the mounts, I'll change them to make sure.
Old May 27, 2005 | 08:09 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
I say just swap for a y8 tranny, upgrade your shifter bushings and motor mount inserts to an ES bushing kit. My EK at 25K miles is stubborn to get into Reverse and would grind once in awhile when it isn't fully engaged into gear, that's why I have to pop it out of gear while stopped and bring it back in.
ABlais
12
Jun 17, 2008 11:25 AM
lawlerlaw
23
Apr 21, 2006 09:11 AM
93egSIboi
24
Feb 10, 2005 04:40 PM
Tadeh
13
Jan 3, 2003 05:22 AM
3rdGteg
Aug 30, 2002 05:40 PM
