Can i make this block work as a daily driver??? lsvtec
Old May 27, 2005 | 11:13 AM
DrewDown's Avatar
Default Can i make this block work as a daily driver??? lsvtec
I just recently bought a block for my car hopeing to do lsvtec swap. I don't want to go all out, just hoping to get like 180 whp and i will be happy. I plan on running a b16 head and maybe type R cams or aftermarket such as skunk 2. Im also lookin to get hondata for fuel management. Anyway the guy i bought the block from barely drove it then went to a b20 vtec. I want to use this as a daily driver on pump gas. So do you guys think it can work. Will the compression be to high? I also keep hearing that it needs to be sleeved. I just want a reliable setup thats more powerfull than the stock ls. I'm just having concerns and wondering if i should sell it or if i can make it work.
Anyway here are the specs.
B18a shortblock.
CTR .25mm oversized pistons.
shotpeened rods.
arp rod bolds
micorpolished crank.
new bearings.
new type R oil pump.
new seals and gaskets.
decked 10 thousandths
the person i bought it from ran it with
b16 head with crower cams, type R intake and 70mm throttle body. custom
header and a few hours on the dyno.
and made 205whp and ran a 12.8 at 105 in a gutted hatchback
Old May 27, 2005 | 11:52 AM
HondaIntegraR's Avatar
Default Re: Can i make this block work as a daily driver??? lsvtec (DrewDown)
yes it can be daily driven, use a very thick headgasket to reduce compression and tuning
Old May 27, 2005 | 12:49 PM
DrewDown's Avatar
will the cometic 43 thousandths be thick enough? What compression do i want to be at in order to run on pump gas?
Old May 27, 2005 | 01:32 PM
Default Re: (DrewDown)
on 91 you probably don't want to me over 11.5 and i don't think a .043" gasket will be enough
Old May 27, 2005 | 05:38 PM
DrewDown's Avatar
whats the thickest headgasket I can get? A .043" headgasket would put me at about 12.1 comp correct. Sorry I am such a noob.
Old May 27, 2005 | 06:09 PM
ShaunRR's Avatar
HT White Ops
Community Builder
You can daily drive on 12:1, if you have a competent tuner.
Old May 27, 2005 | 10:28 PM
Default Re: (rochesterricer)
i believe the .043" gasket would put you around 12.5-12.9
there are thicker headgaskets available, i bought a cometic one for a buddy and i believe it was 0.054"
Old May 31, 2005 | 08:39 AM
DrewDown's Avatar
so i def. want a thicker headgasket than .043 right. How thick can i go. Should i stick with cometic? Thanks for the help
Old Jun 1, 2005 | 10:27 AM
DrewDown's Avatar
bump
Old Jun 1, 2005 | 10:35 AM
i know you can go thicker, cometic makes thick headgaskets so yeah stick with them, also remember you can't go to thick or you'll have sealing problems. contact cometic, they should be able to help you
Old Jun 1, 2005 | 04:51 PM
N_A_is_best's Avatar
Default Re: (HondaIntegraR)
drewdown hey what part of tucson are you in ive probably seen you if your looking for parts man call the shop
raphael
Nov 12, 2007 07:03 AM
DrewDown
Jul 25, 2005 07:00 PM
highrevnef
May 17, 2005 11:15 AM
freezerburnv2
25
Feb 9, 2004 09:00 PM
zum01
Sep 24, 2002 01:01 PM
