Weird Shift Linkage problem pics for help, searched, this one is weird.
Old May 27, 2005 | 10:21 AM
KOALA YUMMIES's Avatar
Default .,
Old May 27, 2005 | 11:41 AM
Deep's Avatar
Default Re: Weird Shift Linkage problem pics for help, searched, this one is weird. (KOALA YUMMIES)
I've had issues with linkages before where basically the linkage was bent so it wouldnt engage into certain gears properly or just wouldnt go but since you guys cut the linkage I would just say thats where the screw up is. Hope that helps....
Good luck.
Old Jun 1, 2005 | 11:23 AM
natesgarage's Avatar
Default Re: Weird Shift Linkage problem pics for help, searched, this one is weird. (Deep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deep &raquo;</TD></TR><TR><TD CLASS="quote">I've had issues with linkages before where basically the linkage was bent so it wouldnt engage into certain gears properly or just wouldnt go but since you guys cut the linkage I would just say thats where the screw up is. Hope that helps....
Good luck.</TD></TR></TABLE>
Look again at the pictures. The linkage isn't bent it's where it comes out of the tranny that is the problem. If you bent something as much as that it would have broken.
Old Jun 1, 2005 | 11:30 AM
Default Re: Weird Shift Linkage problem pics for help, searched, this one is weird. (natesgarage)
bump
Old Jun 1, 2005 | 12:30 PM
saleensolution's Avatar
does the tranny still go through all the gears? all b-series shift linkages are the same the bents are a little different but they all bolt up the same and function the same
Old Jun 1, 2005 | 08:34 PM
Default Re: Weird Shift Linkage problem pics for help, searched, this one is weird. (saleensolution)
Well I have to finish rewelding it to tell you if all the gears work. I know that the forward gears work but I haven't been able to find reverse by moving the shift linkage.
Old Jun 2, 2005 | 12:49 PM
Pootie's Avatar
Looks to me like that tranny was disassembled and not reassembled correctly. I'm betting the piece that moves the shift forks around is not in it's proper groove in that shaft. Sorry, forgot the proper names for those pieces.
Old Jun 3, 2005 | 06:01 PM
Default Re: (Pootie)
Finished welding it will only use first and second. Time for a tranny rebuild
Old Apr 10, 2022 | 07:43 AM
George Knighton's Avatar
H-T Order of Merit
alice has guided commando solo through the looking glass
EkcivichatchLS
Dec 24, 2009 04:41 PM
Vtec92Civic
Sep 4, 2004 01:11 PM
.paul
Jan 30, 2003 01:56 PM
