SHIT Oil Leak..SoCAL help
Old May 27, 2005 | 10:20 AM
NerveAgent's Avatar
Default **** Oil Leak..SoCAL help
Anyone know a reputable shop Around ("the valley" .ie. North Hollywood, Van Nuys, Panorama City) i can bring my car too..I'm leaking oil and i have no idea why.. The person that use to fix car doesn't anymore.
(btw sorry if its in the wrong forum)
Thanks
Old May 27, 2005 | 01:30 PM
VtecDeMoN's Avatar
Default Re: **** Oil Leak..SoCAL help (NerveAgent)
Why not jack it up and take a look? You'd be suprised that it may be as simple as draining the oil and using a new oil pan drain bolt and washer. If you can locate the leak maybe you can do it yourself, might as well give it a try opposed to shelling out unnecessary dough at a shop.
Brian
Old May 27, 2005 | 03:12 PM
Marauder's Avatar
Default Re: **** Oil Leak..SoCAL help (VtecDeMoN)
Where's the oil coming from?
Common places are:
-oil pan
-cam seals
-crank seals
-valve cover
-distributor o-ring seal
Old May 27, 2005 | 04:06 PM
Cboy1-EG6's Avatar
Default Re: **** Oil Leak..SoCAL help (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">
Common places are:
-oil pan
-cam seals
-crank seals
-valve cover
-distributor o-ring seal</TD></TR></TABLE>
I was leaking massive oil not to long ago from my cam seals, head gasket, and I also needed to replace the drain plug gasket(washer). So I went down to the local Kragen/Pepboys and got myself the **** I needed and did it myself. Drain plug is probably the easiest so start from there if ya want. DIY yourself dude don't pay mechanic jerks that overcharge for easy work. Pepboys/Kragen/Autozone=your bestfriend for DIY's.
Old May 27, 2005 | 06:09 PM
1 SiC EJ1's Avatar
yo man if its from ur oil pan gasket good luck dude i replaced my oil pan with new seal new oil pan and new bolts and man that thing still leaked. so its a dreaded honda oil leak which is common with most honda's especially 92-95 civic's so make sure u do it right and take ur time.
jrm
Honda Civic (2001 - 2005)
May 26, 2015 07:32 PM
captainkickass
Mar 27, 2009 07:10 PM
Lauj87
Apr 4, 2007 07:50 PM
Akalima
Jun 21, 2006 07:25 PM
D16Z6_turbo
Aug 26, 2005 04:56 PM
