can you put a h22a type s in a rex?
Old May 27, 2005 | 10:14 AM
LoveOfMoney's Avatar
Default can you put a h22a type s in a rex?
Like the title says.
Old May 27, 2005 | 10:16 AM
Grand's Avatar
you can but its not easy do a search youl find some info on it ill tell you this though theres alot of customizing involved
Old May 27, 2005 | 10:17 AM
kid-crx's Avatar
yes but a lot of custom work to be done
GO FOR IT
Old May 27, 2005 | 10:18 AM
crx-treme's Avatar
Default Re: (supportRhondas)
if its gunna be a track bitch....by all means go for it
i think maybe to front heavy for the street
ManBearPig4silly's Avatar
yes you can. The easiest way would be to use the h2b plate kit and use B mounts. I will be going this route but making my own kit becuase i rule. If you want to use an H tranny talk to 2point2 he did at least a year ago.
Old May 27, 2005 | 11:06 AM
RCautoworks's Avatar
Default Re: (I4sillypwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">yes you can. The easiest way would be to use the h2b plate kit and use B mounts. I will be going this route but making my own kit becuase i rule. If you want to use an H tranny talk to 2point2 he did at least a year ago. </TD></TR></TABLE>
Who are you buying the plate from ? Just curious cause I remember the last seller was kind of a scam artiest. And a new guy is coming out with a plate.
Anyways to the original poster, it can be done, but if you have to ask, more then likely your not gonna be able to handle it.
Old May 27, 2005 | 11:58 AM
fujii13's Avatar
Default Re: (crx-treme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme &raquo;</TD></TR><TR><TD CLASS="quote">i think maybe to front heavy for the street</TD></TR></TABLE>
not if he puts it in the BACK!!
Old May 27, 2005 | 12:36 PM
Hotori Hanso's Avatar
Default Re: (fujii13)
https://honda-tech.com/zerothread?id=711900
https://honda-tech.com/zerothread?id=1126493&page=2
Old May 27, 2005 | 03:19 PM
Nope its not, only 60 pounds more then a b series. Many people run b series with turbos and have no problems.
The only issue would be oil pan clearance.
Old May 27, 2005 | 04:13 PM
kaoss_11's Avatar
B A N N E D
Thats not really even an issue to be honest
Old May 27, 2005 | 04:34 PM
Default Re: (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">Thats not really even an issue to be honest
Yeah I know that, but a lot of other people do not. And the kind of like to spread some miss information
Old May 27, 2005 | 07:52 PM
steronz's Avatar
we need to make a sticky somewhere highly visible saying "H series only adds 60 lbs over B series." I'm sick of people spreading lies about it being front heavy, especially when they have no qualms about putting 60 lbs of turbos/brakes/wheels/etc. on the front end.
Old May 28, 2005 | 12:47 AM
Rywire's Avatar
Default Re: (steronz)
If you plan on street use with the b series mounts, you will need some sort of bash guard, it hangs low for any type of normal city streets IMO. But would be a killer setup.
Old May 28, 2005 | 08:12 AM
if i had the mounts, would it be easier?
Old May 28, 2005 | 08:56 AM
Default Re: (LoveOfMoney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoveOfMoney &raquo;</TD></TR><TR><TD CLASS="quote">if i had the mounts, would it be easier?</TD></TR></TABLE>
Do you know how to weld ? Do you know how to cut metal ? Do you know how to fabricate things if it comes down to it ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">If you plan on street use with the b series mounts, you will need some sort of bash guard, it hangs low for any type of normal city streets IMO. But would be a killer setup.</TD></TR></TABLE>
One of the main reasons why the h22 I'm doing is gonna be strictly drag for now, if I can some how get the clearance good with the ground, I might do another one for a daily driver.
newtyfruits
May 9, 2008 12:56 PM
coronadrinker
Sep 8, 2005 03:01 PM
Crxflo
Oct 24, 2004 08:09 PM
fastest
Sep 22, 2004 10:53 PM
AfEn808
Jan 16, 2002 11:20 PM
