Suspension & Brakes Theory, alignment, spring rates....
Shocks actually lower your car bit???
Old May 27, 2005 | 08:47 AM
Spoon_kid's Avatar
Default Shocks actually lower your car bit???
I'm looking to upgrade my shocks on my 99 ek hatch.
I keep hearing that preformance shocks will actually lower your car a small amount?
I current have Tein S-Tech springs which I believe give about 1.8 drop all around. I wouldnt mind being a little lower, but I want to avoid any rubbing on my rims and or tires.
Is this true? and What would be the best shocks to go with that will give me a good extra drop... wanna get to around 2"
thanks for the input
Old May 27, 2005 | 08:58 AM
be.twenty's Avatar
koni yellows can lower your car approx 3/4" more... i dunno of any other shocks that will had that adjustment unless it's an all out coilover
Old May 27, 2005 | 10:35 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (shogun-dc2)
Koni only recomends using their lowering perches when combined with OEM springs. CRX Lee said that lowering a lowering spring could cause excessive bottoming out because the springs would be too soft for the additional drop...
Old May 27, 2005 | 10:39 AM
be.twenty's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Koni only recomends using their lowering perches when combined with OEM springs. CRX Lee said that lowering a lowering spring could cause excessive bottoming out because the springs would be too soft for the additional drop...</TD></TR></TABLE>
i remember reading that but wasn't 100% sure of the source so i didn't post it...
this weekend i'm actually installing my stock shocks with a new set of yellows on the lowest perch... tired of scraping, bottoming out and not being able to drive downtown toronto..
Old May 27, 2005 | 12:15 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shogun-dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
this weekend i'm actually installing my stock shocks with a new set of yellows on the lowest perch... tired of scraping, bottoming out and not being able to drive downtown toronto.. </TD></TR></TABLE>
I assume you ment "stock springs"...
Old May 27, 2005 | 12:49 PM
be.twenty's Avatar
drrr... springs... thanks..
beastman@
Oct 10, 2007 01:08 PM
white90crxhf
Suspension & Brakes
Feb 20, 2007 08:32 PM
redDAinteg
Oct 14, 2005 08:10 PM
popoychu
Nov 11, 2003 08:04 AM
Integra187
Mar 26, 2002 07:38 PM
