Base Map for the E-manage for 6th Gen Accord
Old May 27, 2005 | 08:20 AM
Excelerate's Avatar
Default Base Map for the E-manage for 6th Gen Accord
Hey guys, I have a '99 Accord i4 w/ FMAX kit. Basically a T3/T04 running 9psi. I modified the fuel management though to be 4 DSM 450's and I am using the Greddy Emanage w/ support tool. I also have the LM-1 w/ RPM converter kit.
Quick side question: What type of ignition setup do we have so I can program the RPM converter for the LM-1? Is it 2 pulses per crank rotation?
Ok, back to the real issue: I need a base map so I can have something to work with. I am pretty sure turbowa had the same setup and someone else but I could use some help.
Old May 27, 2005 | 01:06 PM
Excelerate's Avatar
Default Re: Base Map for the E-manage for 6th Gen Accord (Excelerate)
ttt
Old May 27, 2005 | 09:39 PM
Excelerate's Avatar
bump for some help
Old May 31, 2005 | 12:31 PM
Excelerate's Avatar
ttt
Old May 31, 2005 | 12:36 PM
notoriousB's Avatar
you probably already know this, but there are no greddy-supplied base maps, you'll have to be real lucky to find someone who is running an F using e-manage who will share their map with you...
you'd probably be better off finding a tuner who knows e-manage and just get it fully tuned.
Old May 31, 2005 | 01:16 PM
Excelerate's Avatar
Default Re: Base Map for the E-manage for 6th Gen Accord (notoriousB)
Hey notoriousB I spoke to you before about the emanage. I know that you had offered some help on this in terms of the VAFC numbers but I do know there was at least one other guy with the same setup (turbowa) and one other guy I think to.
Also, who tunes the Emanage in Connecticut or even in the Northeast?
youngboiCD7
Engine Management and Tuning
Apr 12, 2018 06:13 AM
02 accord
May 16, 2009 09:13 PM
Emshhh
Nov 26, 2006 10:26 AM
Excelerate
Jun 2, 2005 07:36 AM
