how do u convert obd-0 to obd-2?
Old May 26, 2005 | 11:09 PM
.M.'s Avatar
.M.
Default how do u convert obd-0 to obd-2?
doing ls/vtec and i need to know how do convert a obd-0 distributor to an obd-2?
EDIT: i need to know what color wires connect to where from the obd-0 to obd-2 harness cuz the colors are different
Modified by Jh4dC4# at 11:32 AM 5/27/2005
Old May 26, 2005 | 11:15 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: how do u convert obd-0 to obd-2? (Jh4dC4#)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">keep the ls dist and the ls ecu and it should workout.</TD></TR></TABLE>
Last time I checked, the ls ecu cant control vtec. I know you can get it modified for vtec, but I assume you already have a OBD 2 ecu if you want to convert your distributor to OBD 2. However...
You cant convert the distributor. If you're doing ls/vtec, you need to locate a distributor that matches the ecu. So if your going with a OBD 2 ecu, then you need to find a distributor from a 00 si or a 97-00 GSR.
Old May 27, 2005 | 09:30 AM
.M.'s Avatar
.M.
Default Re: how do u convert obd-0 to obd-2? (carma_626)
bump.
Old May 27, 2005 | 09:59 AM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 &raquo;</TD></TR><TR><TD CLASS="quote">
You cant convert the distributor. If you're doing ls/vtec, you need to locate a distributor that matches the ecu. So if your going with a OBD 2 ecu, then you need to find a distributor from a 00 si or a 97-00 GSR.</TD></TR></TABLE>
he just told you
Old May 27, 2005 | 10:13 AM
Jayel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 &raquo;</TD></TR><TR><TD CLASS="quote">You cant convert the distributor. If you're doing ls/vtec, you need to locate a distributor that matches the ecu. So if your going with a OBD 2 ecu, then you need to find a distributor from a 00 si or a 97-00 GSR.</TD></TR></TABLE>
Exactly. What else do you want to hear?
You cannot convert your distributor. Go find yourself a OBD2 dizzy beyotch!
Old May 27, 2005 | 10:33 AM
.M.'s Avatar
.M.
Default Re: how do u convert obd-0 to obd-2? (Jayel)
edit;
Old May 27, 2005 | 07:43 PM
.M.'s Avatar
.M.
uppp !!!!!
Built4Battle
Jan 23, 2011 09:46 AM
kcvi3tstyl3
Apr 6, 2009 08:32 PM
.M.
May 27, 2005 08:18 PM
97L-esVeeTeg
13
Jun 2, 2004 12:21 PM
boot machine 5000
Jan 14, 2002 09:32 PM
