car acting up
Old May 26, 2005 | 08:50 PM
pr_tony_montana's Avatar
Default car acting up
what do you guys think is wrong w/ my car. I had a b18b installed a couple months ago it was throwing a cel code 41 and I fixed it. The car is sputtering/bogging and hessitating during acceleration, once it gets a little high in the rpms its fine. I thought it could be my spark plugs but I changed those out and its still doing it. Only thing I can think of is fuel filter or fuel pump maybe. I'm still using the dx fuel pump.
Old May 26, 2005 | 09:02 PM
neutron91's Avatar
Default Re: car acting up (pr_tony_montana)
check timing
Old May 26, 2005 | 10:11 PM
TsukubaDreams's Avatar
Change out your fuel filter and rotor cap. should solve your prob.
Old May 26, 2005 | 10:27 PM
Status Sean's Avatar
Default Re: car acting up (TsukubaDreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TsukubaDreams &raquo;</TD></TR><TR><TD CLASS="quote">Change out your fuel filter and rotor cap. should solve your prob.</TD></TR></TABLE>
Old May 26, 2005 | 11:36 PM
Default Re: car acting up (rw92civic)
I'll probably try the fuel filter and timing first cause they are cheaper.
Old May 27, 2005 | 01:00 AM
you guys think it could be my fuel pump? I'm still using the dx fuel pump.
Old May 27, 2005 | 01:07 AM
siregcivic's Avatar
check your timing belt timing on the cam gears. also i had that problem and it ended bieng a faulty fuel injector. sounded like a subey until 4 grand then it straigtened out.
Old May 27, 2005 | 01:09 AM
_Cyclone_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr_tony_montana &raquo;</TD></TR><TR><TD CLASS="quote">you guys think it could be my fuel pump? I'm still using the dx fuel pump.</TD></TR></TABLE>
Probably not... try checking ignition/valve timing and the basic tuneup (cap, rotor, wires, plugs, fuel filter, decarbon) first before you start worring about replacing more major parts.
Briman2021
Jul 22, 2006 08:01 PM
crnimacak
Apr 21, 2006 10:11 PM
xtegb16x
Oct 30, 2005 12:20 PM
civiccoupe94
Jul 5, 2005 08:12 AM
KaiITR
Jun 17, 2003 07:51 AM
