whats this wire for?
What is the wire from the valve cover to the frame where the AC condenser goes?? its because mine is cut and i wanna know if i should fix it or just leave it alone
If one of your grounds isn't hooked up, then you run the possibility of an engine fire because the other one will have too much electricity running through it.
Aww Come on Bauley... Dont scare the guy he is still a newb... LOL
But anyway... You should hook up ALL grounds because they are very important to your engines performance... I don't mean those stupid ground kits, But factory ground reference is very important to sensor accuracy, go outside and hook that bad boy back up.. Honda-Tech Orders!!!!LOL
BTW Just guess why many people with a hondas have hunting idles (up-down-up-down) Hint-hint its related to this topic... Good luck!!
hay i went out and accualy spent money, hay i was young dumb and ugley, well im still ugley, but anyways i notice if you dont have your grounds hooked up you can get a rough idle, once i put the grounds on i notice i had better over all electronics and, better idle and better sounding stero, i i think i did... but there there for a reason..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canis »</TD></TR><TR><TD CLASS="quote">hay i went out and accualy spent money, hay i was young dumb and ugley, well im still ugley, but anyways i notice if you dont have your grounds hooked up you can get a rough idle, once i put the grounds on i notice i had better over all electronics and, better idle and better sounding stero, i i think i did... but there there for a reason.. </TD></TR></TABLE>
...what?
...what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5poonhatch »</TD></TR><TR><TD CLASS="quote">and and u call me a newb CMON!!!! is it cuse im 15????</TD></TR></TABLE>
no I called you that because it say Noob in your avatar.......no biggie we all were at some point or another... Its all in fun. Definately learn not to take everything on Honda-tech seriously... you will enjoy your stay here a WHOLE lot more...
i would put my car as my avatar but is says it has to be under 25000 bytes and i dont know how to change it but if u know how to change it please tell me
Jonathan_ED3
Welding / Fabrication
13
Sep 27, 2005 07:12 PM
